152L2 (VNA) 1960
152L2 (VNA) 1960
Hello,
If I wanted to change my electrical system on my 125cc 152L2 (VNA) Vespa from 6v to 12v what would my options be and is it worth the money?
I have looked around at a few kits claiming its 'plug and play' with electronic ignition etc and simply the bits plug together? So I have a few questions?
1) Will I need to change my wiring loom? - Looking into it I think I will as I will have to add a battery etc which I currently don't have
2) Is the timing setup the same as the original magneto (ie by moving the slotted plate to adjust the advance?)
3) Will I need to add fuses (as ive read somewhere that my old scooter simply uses the lamps as fuses to protect the circuit as its soo simple?
4) Using 12v DC setup instead of 6v AC I guess lamps etc are readily available?
I can certainly see some advantages, however having just rebuilt my scooter and got my engine running nicely, it's a pretty big step back having to changeover to a 12v setup. Not that I wouldn't be able to do it, but just need to justify the benefits of spending the money first!?!
Anyway any feedback or advice would be helpful! Also if anyone has converted their scooter, advice would be good...
@sgn_scott avatar
Sprint 166, P150S
@sgn_scott avatar
Sprint 166, P150S
I'll remove one headache for you. Going to 12V doesn't mean that you need a battery. I don't have one and run a 12v CDI set-up.
There may be some small changes to loom needed but those should be covered by whatever kit you buy.
The kits normally come with a regulator of sorts so you'll just need to switch over to the correct 12v bulbs (again normally supplied in the kits)
Hope that helps.
@oopsclunkthud avatar
3:5
With a VNA I would not bother converting to 12V. A good working 6V system should give you plenty of light. They DO make 6V halogen bulbs.
61 vnb
61 vnb
I second what oopsclunkthud said . Halogen 6 volt would be the way to go . As bright as a stock 12 v. The ones I have had you will have to change out the bulb holder also . Easy to do and worth it .
152L2 (VNA) 1960
152L2 (VNA) 1960
thanks for your help!
will order a halogen lamp and get a regulator then and go from there!
@nebulae avatar
Vespa Rally 210
@nebulae avatar
Vespa Rally 210
The best thing with modern electrics isn't just to do with 12v, its also to do away with pre-historic ignition points & go electronic ignition.
Defo worth considering.
The upgrade to 12v just gets thrown in for free
3:5
The upgrade to 12v just gets thrown in for free :D
electronic ignition is great but really only has an advantage at high RPM. A vna motor isn't likely to see high RPM and is not really tunable so the advantage will not really show itself in this application.
@nebulae avatar
Vespa Rally 210
@nebulae avatar
Vespa Rally 210
Oh come on.
Points are mechanical bits of gear that need adjusting & wear out over time.
Having electronic ignition to get rid of them is excuse enough, never mind the other advantage that you spek of.
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
i agree with oopsclunkthud. im on my second set of points after 5 years. they are also hella cheaper than a CDI to replace.
[ Time: 0.0247s ][ Queries: 3 (0.0042s) ][ Debug on ][ 313 ][ Thing One ]
