@cwilliams21 avatar
2007 Silver LX150
@cwilliams21 avatar
2007 Silver LX150
Hello-
I'm thinking about getting a HID headlight kit for my 2012 GTS300 but I would like to know if any member has experience with the kit below. I'd like to know build quality, durability, ease of installation etc.
http://www.scooterworks.com/[redacted]-headlight-upgrade--xenon-hid---vespa-gts-products-543.php
I tired searching the forum before posting this but didn't find anything about this kit. Any input is appreciated!
@miguel avatar
@miguel avatar
I have one of these that I purchased with hopes of upgrading my GTV. I have decided against it and am interesting in selling it. PM me if you are interested in it.
Best
Miguel
@2011super avatar
2021 GTS 300 Touring
@2011super avatar
Best
Miguel
Why did you decide against it?
@ljclark avatar
None
@ljclark avatar
None
Re: HID headlight for 2012 GTS300
cwilliams21 wrote:
Hello-
One thing I notice about this kit is that there is a shield over the front of the bulb. Almost all of the plug-in "kits" don't have that. The issue is that 99.9% of North American automotive and PTW low-beam headlight bulbs have a painted cap or are mounted behind a shield -- so all the light projected forward is off the reflector -- and thus NOT exposing the filament (or spark or arc) directly to oncoming traffic. That's the reason I won't mount any of those many other HIDs into a low-beam fixture.
According to S-c-o-o-t-R-S's site, their kit is fully functional like a standard H4 dual filament bulb.
@tb avatar
@tb avatar
If you're going to mount an HID headlamp, try and use on that is a Projection Unit. This will allow the beam of light to be projected properly and you can control the low and high beam with the projectors shutter mechanism. This is what I have installed. It is a daunting install and would only recommend it only if you're convinced that this is the path you want to take.
IMHO, You do not want to have an HID lamp that projects off of the reflector in you standard headlight housing as it was designed for the incandescent lamp and not an HID.
I did install a "plug and play" type and did not like the scattered beam inability to control same. It's really not good to have an HID beam shooting up and out to on coming traffic when you have you low beam set.
Others may want to chime in and you can decide what you want installed.
Good Luck!
@vezpa avatar
@vezpa avatar
I have fooled around with many aftermarket HID kits and they are usually junk. They will also get so hot in the GTS housing that they may very well melt the lens. If you want the best light-bulb go get a Sylvania Silver Star as they are pretty much the best bulb on the market and will only set you back about $20
@2011super avatar
@2011super avatar
I ran an HID on my 2007 for about 4 years and it worked perfectly with no issues. Loved it but have no real plans to do any upgrades on this bike other than the horn for letting texting cagers they are about the run over me.
@tb avatar
@tb avatar
You are correct, it can be a crap shoot.
I just got a new shroud (surrounds HID projector) and a supposed improved HID bulb to replace the shroud that had installed and got deformed (melted). The headlight lens is fine. Consulting a good friend, we are going to replace the shroud and use the new HID bulb. Then we are going to drill some holes on the underside of the lens to allow some air flow. If this doesn't work I will order a new headlight housing and use standard incandescent bulbs (i.e. the Sylvania Silver Star).
Since I have my turn signals modified; dual white running lights (always on) and amber turn signals...I believe my visibility is enhanced from what I had (no running lights).
Note: Objective was to been more visible on the road.
[ Time: 0.0277s ][ Queries: 3 (0.0056s) ][ Debug on ][ 313 ][ Thing One ]
