Vespa LX 50 4T 4V
Vespa LX 50 4T 4V
So my question is how to remove the plasticky original handlebars on my Vespa Lx. Im thinking of changing them to ones which have a leatherlike look and chrome on the end.
If you mean the hand-grips, on an LX you will have to cut them in one way or another to get them off easily as they have closed ends. Lengthways is quickest and easiest...
On other models with bar-ends, a long screwdriver and some WD-40 does the trick, or compressed air if you have some handy - which leaves them re-useable.
Vespa LX 50 4T 4V
Vespa LX 50 4T 4V
So am I right that there is no way to get the hand-grips off in any reasonable way and still keeping them usable for the future?
It might be possible by removing the headset to get underneath the rubber from the steering column end - but as the grips are cheap and you're replacing anyway, why worry?
Vespa LX 50 4T 4V
Vespa LX 50 4T 4V
Thats right. Then how about putting the new ones on, what method do I use to do this?
They should come with instructions and some glue. Basically they are slip-on and glued in place, no high-tech involved.
Just make sure you get the right size, there are two main sizes and the smaller one (often referred to as 7/8") is the one you want.
Vespa LX 50 4T 4V
Vespa LX 50 4T 4V
Thanks. Lets see what is the outcome.
[ Time: 0.0255s ][ Queries: 3 (0.0060s) ][ Debug on ][ 313 ][ Thing One ]
