@victor1 avatar
2011 LX150ie two tone expresso
@victor1 avatar
I had some damage to the front and back headset on my lx150, so ordered replacements. Am having a problem getting it to fit . The back fits tight against the metal brackets, so assume its seated correctly. Front section, left grip side is fine as is everything up to the fit under the right grip. Seems as if there just isn't enough of the front headset to come under the grip and meet with the back. Have checked and rechecked to see if there is wiring or something else obstructing the right side, don't see anything. Anyone have any suggestions? Dealer input? I have to assume the replacement parts are ok as they all come from the same mold. help. thanks.
@bluecloud avatar
2018 GTS Super
@bluecloud avatar
2018 GTS Super
victor1 wrote:
I had some damage to the front and back headset on my lx150.
Damage?
Any possibility the mounting brackets on the handlebar are bent?
@victor1 avatar
@victor1 avatar
bluecloud wrote:
Damage?
Thank you, but they are not bent as the damage was just broken plastic from over tightening one of the lower screws that hold the two sections together.
@15pap15 avatar
09 LX150, 04 ZX-10r
@15pap15 avatar
09 LX150, 04 ZX-10r
Your turn signal wires may be getting caught when assembling,
It may be hitting the horn cover
[ Time: 0.0097s ][ Queries: 3 (0.0015s) ][ live ][ 343 ][ ThingOne ]
