@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
At EIMCA in Milaan DrP introduced the Flying roller
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
btw i've arrived bak home Clown emoticon
@klaborde avatar
@klaborde avatar
Re: New DR-Pulleys
This looks interesting,
I assume the point of wear would be the "Plastic or Nylon" vs the roller itself.
I wonder due to the lack of complete coverage like DR Pulley, if they could crack over time and have early failure?
I have tried both DR Pulley's and Stock, and to be honest I can't really tell that much huge of a difference based on my use. I have observed when replacing the "Sliders", they require some break in period to allow the RPM's to drop back to the norm. When they are new, the RPM's run a higher.
Thanks for Sharing,
Keith
Marietta, GA
@yayadave avatar
MP3 500 - GTV250
@yayadave avatar
MP3 500 - GTV250
This is interesting. Thanks for the update. What's supposed to be the benefit? Smoother starts? Longer wear?
Hope you had a good visit over here.
I imagine the benefit is that the centre brass weight doesn't have to be replaced - only the outer shell if/when it has worn. This should make replacements a lot cheaper to manufacture and ship, plus it's more environmentally sympathetic. A win-win.
@fuzzy avatar
@fuzzy avatar
Glad some smart people are trying to improve on an age old design. Their sliders are a definite improvement and this next step is interesting.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
I am thinking this is not Dr. Pulley but Tech Pulley.
@fuzzy avatar
@fuzzy avatar
Little something more going on in the design. Notice than when the brass weight starts to move the plastic will roll until the lip comes in contact. They need to show the contact with the fixed piece the slider pushes against and a sequence of pictures of how it moves. An explanation of benefit vs our expert assumptions would also be good.
There is a better way to most designs just waiting for someone to think of it.
@garvel avatar
Piaggio MP3 LT 500 Sport 2012
@garvel avatar
@scewter avatar
MP3 400
@scewter avatar
MP3 400
@mpfrank avatar
@mpfrank avatar
Higher revs for takeoff...
Lower revs for higher top speed...
Sounds great so far.
@sidecutter avatar
2009 MP3 400ie, Silver- "Lorelei Lee Long"
@sidecutter avatar
Hmmmmmm...interesting. If they make them in the right size, the lack of an actual MP3 version should be irrelevant, yes?
Scewter wrote:
looks like the FR2522 is what will work according to tech pulley
@heinlein avatar
MP3 500, Ducati ST4s, Honda Silver Wing
@heinlein avatar
old as dirt wrote:
A search brought me to this thread I had missed until now. Has anyone tried these yet?
Maksor chime in please
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
they are only for 50cc engines Crying or Very sad emoticon a option is to fill your Cylinder so it will be a 50cc Clown emoticon
@ponydrvr avatar
Honda CTX 700D
@ponydrvr avatar
Honda CTX 700D
I saw some listed for the Beverly 500 LT on their website.
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
your right they got more now but nothing for the mp3
the one for the Bev are the old ones FR2522 25 x 22.2
and no 25x17
@heinlein avatar
@heinlein avatar
and no 25x17
I know the 25 x 17s are what many people feel is optimal for the DPs. Are you sure the same applies to these newfangled contraptions?
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
25x17 is the seize 25mm by 17mm and have 8 weights and 19 (400) 21(500cc)
the older 460cc engines got 25x22 and do have 6 weights 27gram as stock
i've listed them on my site
SP2517/8 xxGr + SP2517-P
and the
older one
SP2522/6 xxgr + SP2517-p but then you have on3 SP left over the old vario uses 3 SP's
[ Time: 0.0126s ][ Queries: 4 (0.0047s) ][ live ][ 343 ][ ThingOne ]
