Nope. I don't think there is a full faced helmet that will fit under the seat of an LX. However, if it has D rings you can attach it to the hook under the seat to keep it safe while you're away.
Thanks! I really like that helmet and used to have one while I lived in Bermuda but didn't have a Vespa then... I am still a little unsure if i would want to attach it with the D ring when I park on the streets of NYC.
Posts: 1495 Location: The New World |
Moderator Australis
Posts: 5708 Location: New Zealand where it is already tomorrow.. |
Piaggio BV350, Aprilia Sportcity One 125, Suzuki SV650
Posts: 37 Location: San Francisco, CA |
2009 Vespa LX150ie, 2007 GTS250ie, 1982 Honda CB900F, 1989 BMW K100RS
Posts: 1075 Location: Sydney Australia |
Len Smith wrote: Nope. I don't think there is a full faced helmet that will fit under the seat of an LX. However, if it has D rings you can attach it to the hook under the seat to keep it safe while you're away. The trilogy is quite a small form factor helmet so it might just be on of the helmets that fit. A reasonable shop should let you try it, as well as letting you try it on your head! |
No need to be sorry, that's potentially good news for the OP. I have never been able to fit any ff helmet even in the larger GT200 bucket, so I assumed the LX bucket would be even smaller.
I hope it works for the OP. |
Thanks all, I think I am going to stop by a shop that has them and see if it will fit.
Will post here once I tried it and know the answer. |
joedevola wrote: zombies-nyc wrote: The trilogy doesn't have d-rings. |
Have had LX scooter (sold earlier this year) and N43 helmet, it will not fit under the seat, but it will fit in the Vespa-branded topbox for an LX (barely, you have to orient it just right, but once you learn the position it is easy to close/lock the topbox lid with the N43 inside)
edit: my N43 (that wont fit in underseat bucket, but did fit in LX topbox) is a medium, not a large (as the OP asked about) |
