Bill Mayer heated seat with 2 levels (high and low) of heat for both front and rear wrapped in leather!
Penskie Suspension for front and rear
HeliBars Triple Clamp Handlebars
Cal-Sci Tall +5.5 Windshield
Dual HID lights that are nothing short of amazing at night
Autovox cruise control that self adjusts for hills to keep speed unchanged
Full Autocom set up and I am throwing in these Nolen helmets with Autocom already wired in if you want them
Kenwood radio under the seat wired for bike to bike communication with the push of a button!
Yamaha Top Case with the metal bracket on the bottom added!
Smart Tire tire pressure monitoring system for both air pressure and heat in both tires that will alert you when air is running low
Peg lowering kit for both front rider and rear passenger with larger aftermarket pegs for the pillion.
Wireless Dual Portable Heat-troller wired for front rider, and wireless Dual Portable Heat-troller for pillion. Not cheap!
Aftermarket freeway pegs
Helmet locks on both sides of the bike that are keyed to the same key you use to start your bike. Great for long rides when your bike is loaded and you need a place to store your helmets
Skyway Sliders
Voltmeter added with switch
Pigtail that allows you to charge the battery when not in use
PR2 tires with only 2000 miles on them
Zumo 660 with the metal bracket that will allow you to take phone calls and listen to music. This was about $1000 with lifetime maps and is included. (small plastic part on power button missing)
Aftermarket R1 mirrors that allow you to see behind you much better than the stock mirrors
