live in brigantine nj - flood water got into my fly 150 muffler - when i try to start - it spits it out - any suggestions on how to remove water from muffler - engine ran on quick start spray so i guess spark plug must be ok - just will not keep running ...air filter in and engine intake hoses are dry and clean
It's possible that water entered the engine from the exhaust. I would drain and refill oil, clean are re-oil air filter foam, and change the spark plug.
The spark plug may be good enough to start on starter fluid, but it should still be replaced.
