@raputtak avatar
@raputtak avatar
Last year I installed a 12v ciggy outlet in the left-hand knee pad. Works just fine except that on bumpy roads, such as my three hour ride to Richmond this past weekend, I found that the GPS plug kept vibrating out. I'd get the "Power down in three-tenths of a nano-second" message.
The fix (well, fudge)? I found that if I put a bit of tension on the power cord when I wrap it around the RAM mount it holds the plug in place. I can't put too much, though, as the handles bars have to turn.
There must be a better solution.
@sharpcolorado avatar
2012 GTV 300 & LXV 150
You need more friction.
A small segment of friction tape can be placed around the plug, and underneath / avoiding the contacts.
@silver_streak avatar
Don't we all?
@dougl avatar
El Macho
Vespa GTS 310
El Macho
@dougl avatar
Vespa GTS 310
I sorted this by bending the ground springs on the power plug. Increases the friction.
[ Time: 0.0105s ][ Queries: 3 (0.0030s) ][ live ][ 339 ][ ThingOne ]
