Hi All,
After 5 years my original battery (Yuasa YXT12-bs) finally gave up the ghost. Given that there are only a few weeks or days of riding left here in the great white north, I raced out to get a new battery and install it immediately to get the last few rides in. After charging it up i installed it and rode to work (20 minute commute). It started right up after work but after arriving home and letting it sit for 10 minutes I went to start and it was dead. So on the charger again. Same thing the next day. I don't have a voltmeter yet so haven't been able check the voltage when at idle or higher revs. But I am wondering if the battery might not be charging due to:1) the relatively short commute; 2) the fact that it has been so cold of late that I am running the heated grips constantly and;3) construction has slowed traffic to the point that for at least half the commute home I am sitting still in traffic. Normally I've been able to turn the heated grips off for the afternoon ride home but temps have been hovering around zero (32F) most days and mornings are -4--8 (~18-27 F) so they stay on. Anyway I am hoping to ride until there is ice but can't say I am confident that I am not discharging the battery on the commute..... i guess that it will recharge some at work and likely crank over for the return trip. So to my question after the rather long intro..Is it likely that the heated grips are drawing enough to prevent the battery from charging?
