has anyone fabricated there own exhaust? i've lots of parts i can use, does a et4 system need back pressure or not?
cheers chris.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
Re: fabricated exhaust?
Chris,
Yes, you need some amount of backpressure in the system. An exhaust with no backpressure will only work well at high RPM and in the case of a CVT scooter, you are not dealing with RPMs in a very high range. Without backpressure you will get a lot of stumbling at low RPM and a rough idle.
All that said, your scooter can benefit from a decrease in backpressure up to a point. You really need to open up the intake side a bit if you want to take full advantage. And you'll need to add a bit more fuel to go along with the additional air flow. So count on a jet change (carb) or update to your fuel injection map.
-Craig
@silver_streak avatar
It's all limited by the cylinder head/valves on a Leader 125/150 engine unless you have access to the kind of machine shop Dynagrego apparently does in his great thread over in the Project Reports section.
[ Time: 0.0119s ][ Queries: 3 (0.0026s) ][ live ][ 339 ][ ThingOne ]
