Vespa GT 125
Vespa GT 125
Hi again,ive had a Dave Cooper scooter rack in the shed for a while,its excellent,i had it on my ford Maverick 4x4 and it carried my p200 on the back effortlessly.Ive moved on since then and have just bought a Ford transit camper and am hoping to use it on this but the max load is 115 kilos for the rack.Dont have the PX now have a 2004 gt125 ,they certainly feal a lot heavier.So thats my question ,how heavy are they wet or dry? cheers Pete
@boulty avatar
Moderator Australis
Moderator Australis
@boulty avatar
Model: Vespa Granturismo 125 L
Year: 2005
Category: Scooter
Rating: 62.9 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 124.00 ccm (7.57 cubic inches)
Engine type: Single cylinder, four-stroke
Power: 14.75 HP (10.8 kW)) @ 10000 RPM
Top speed: 102.0 km/h (63.4 mph)
Bore x stroke: 57.0 x 48.6 mm (2.2 x 1.9 inches)
Valves per cylinder: 4
Fuel control: SOHC
Ignition: Electronic CDI, variable spark advance
Lubrication system: Wet sump
Cooling system: Liquid
Gearbox: Automatic
Clutch: Automatic dry centrifugal type
Fuel consumption: 25.00 litres/100 km (4.0 km/l or 9.41 mpg)
Greenhouse gases: 580.0 CO2 g/km. (CO2 - Carbon dioxide emission)
Chassis, suspension, brakes and wheels
Frame type: Pressed steel monocoque
Front suspension: Single-arm with dual-acting hydraulic shock absorber and co-axial spring
Rear suspension: Twin dual action shock absorbers with adjustable pre-load
Front tyre dimensions: 120/70-12
Rear tyre dimensions: 130/70-12
Front brakes: Single disc
Front brakes diameter: 220 mm (8.7 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Physical measures and capacities
Dry weight: 138.0 kg (304.2 pounds)
Power/weight ratio: 0.1069 HP/kg
Seat height: 790 mm (31.1 inches) If adjustable, lowest setting.
Overall length: 1,940 mm (76.4 inches)
Overall width: 700 mm (27.6 inches)
Wheelbase: 1,395 mm (54.9 inches)
Fuel capacity: 10.00 litres (2.64 gallons)
Other specifications
Starter: Electric
Vespa GT 125
Vespa GT 125
Thanks Boulty ..i guess ill leave it in the shed lol
[ Time: 0.0075s ][ Queries: 3 (0.0016s) ][ live ][ 343 ][ ThingOne ]
