Lite comes on with acceleration then go's off, stays off most of the time while rolling but comes on during heavy acceleration ie: passing, then go's out, not on at idle. Head lite and dash lites dim and then return to full brightness but head-lite dimms to 30% or less output. intermittent.
oil with in limits
coolant with in limits
check voltage at battery- idle 9.9 volt dc
at speed ( no tach so I made guess as to rpm) 3500+ highest voltage 11.82 volts dc.
I do not belive this to be a voltage reg problem but a charging system problem.
