@mikeh56 avatar
mp3 250
@mikeh56 avatar
mp3 250
Engine light intermittently comes on. What have been some causes from other riders. It stated after I tried toggling between High and low beams to simulate both lights on. Also the exhaust bushing has worn out and causing possible problems. Any feed back appreciated.
@sidecutter avatar
2009 MP3 400ie, Silver- "Lorelei Lee Long"
@sidecutter avatar
Take it down to the dealer and have them check the codes being put out. Anything else is just a guess, and it's better to know.
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
If your check engine light is coming on when your rpm increases but off at idle then you may have a bad voltage regulator. It happened on my 250 so I did a wiki on it. Have a look. MP3 250: Removal of the voltage regulator
@stickyfrog avatar
Moderatus Rana
Moderatus Rana
@stickyfrog avatar
Oh and if you find this is the case do not ride until you get it fixed or you will cook your battery.
@klaborde avatar
@klaborde avatar
Easy to get to like Sticky said to replace.
Dam GTS, it's a nightmare to replace where its located.
I forgot to see if the person who made the orignal post was in the US.
The best price I have seen on this part is AF1 Racing by the way.
I ordered one a few months ago.
Keith,
Marietta, GA
[ Time: 0.2553s ][ Queries: 6 (0.2461s) ][ live ][ 342 ][ ThingOne ]
