@stephenlamb avatar
@stephenlamb avatar
1979 50 s with a 125cc engine and a malossi 135cc kit and a dellorto 25 carb. so the oil/fuel is leaking where the exhaust connects to the engine and where it wraps around and connects to the tunned exhaust this is leaking so much it will drips down on the rim solid black. my qusetions is why is there so much oil/fuel going thru my exhaust? i know i should replace the gaskets and this would help but thats not the problem is it? just not sure why its not being burnt up in my engine i made the fuel a little leaner and its the same
nothing at all
nothing at all
To me it sounds like two issues.
One is the gasket area(showing the second issue), which I'm gonna guess is over jetted and/or high ratio fuel oil mix.
How does it run?
And what percentage do you mix?
@stephenlamb avatar
@stephenlamb avatar
starts on the first kick idles great. ran great and supper fast now it seem that when its at high rpms in any of the gears it seem to loose power the rev sound inconsistent. when i first sall the leak and noticed the loss of power i thought maybe head gasket? i mix it 2% its just so beautiful makes me sad its my account pic
nothing at all
nothing at all
Hmm
The kit you have is cool and the carb is a good size.
I'm gonna say to check/repair the gasket and manifold areas first.
@stephenlamb avatar
@stephenlamb avatar
Would an exhaust leak cause it to stumble at high and should there b the so much oil/fuel going threw it??
nothing at all
nothing at all
I don't know whats going on with your bike.
But from what you have stated, you have issues with manifold leaks.
Smallframes are very very sensitive. If there is one thing wacky then it can effect the running. Not as forgiving as lets say a P series.
So I suggest you double check/repair any exaust leaks then move on to possible overjetting or ?
What you are seeing more than likely is un-spent fuel.
The 2t is designed to burn a percentage of un-burt gases.
If you have an exhaust issue than maybe you are seeing the drippings of that.
*You can not properly tune your carb if you have exhaust issues or as I have mentioned many times, old clogged pipes.*
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
sure and no
[ Time: 0.0226s ][ Queries: 3 (0.0028s) ][ Debug on ][ 313 ][ Thing One ]
