@rocketman avatar
ET2,GT200
@rocketman avatar
ET2,GT200
How difficult is it to replace a starter on an et2 ?
@greg531 avatar
@greg531 avatar
It's not hard, but clean the drive unit first, and see if it's all gunked up, and clean it out with some carb cleaner and a q-tip....and compressed air....
My Typhoon had issues with that....and fixed the starter problem....
The drive unit comes out by just removing the variator cover....no need to to remove the Drive belt, and variator.....I also put a little lithium grease on the starter drive ends, before reassembly....
@boufie avatar
2003 ET4
@boufie avatar
2003 ET4
Check this post in the Wiki, shows you how to get to the Bendix gear. It is for an LX150 which is probably very similar:
https://modernvespa.com/forum/wiki-lx150-variator-roller-change-bendix-gear-cleaning
[ Time: 0.0089s ][ Queries: 3 (0.0024s) ][ live ][ 343 ][ ThingOne ]
