Lynn
Guys I got most of an order together for giving the 1963 vespa vbb 150cc some new life but I'm just a bit stumped on the carb as to what it's referred to as in model/ type there for it makes it difficult ordering a carb kit. Can you fill in the blanks?please tell me a bit about the carb,type model and anything else thAt may help in its performance?
![]() ![]() ![]() ![]() Thanks Lynn |
si 20/15 http://www.scootermercato.com/Scooter-Parts/Carb-Gasket-Kits/154754-KIT
you need a new air filter too. What's that black stuff in the airbox? |
matty5 wrote: si 20/15 http://www.scootermercato.com/Scooter-Parts/Carb-Gasket-Kits/154754-KIT you need a new air filter too. What's that black stuff in the airbox? |
64 vbb,55 150D, 59 S1 LI200, 60 api, 63 Teevee 175, 1972 Frankenserveta 190, 197? SIL Vijai Super GP150, stella
Posts: 314 Location: Mankato, MN |
They are all the same so that kit will work with your carb.
And the air filter: http://www.scootermercato.com/Scooter-Parts/Air-Filters/Z019 You'll need to clean all your jets yourself as scooter carb kits won't come with the jets like they sometimes do with motorcycles. |
I'd also look into a cable kit as I wouldn't trust what's go on in there even for a spin around the block:
http://www.scootermercato.com/Scooter-Parts/Complete-Cables/CCKRALLY Once you've established whatever that black stuff is, get rid of it and whatever was causing it. Also, I haven't seen a carb box lid in any of your pictures so if you don't have one: http://www.scootermercato.com/Scooter-Parts/Carb-Boxes-and-Covers/87778 And the rubber kit that goes with it: http://www.scootermercato.com/Scooter-Parts/Gaskets_2/58853 http://www.scootermercato.com/Scooter-Parts/Grommets/58364 http://www.scootermercato.com/Scooter-Parts/Plugs/50274 http://www.scootermercato.com/Scooter-Parts/Plugs/87975 |
Thanks guys I'll order up the carb kit and filter. I did order a cable kit that covers the whole bike, along with all other wear items I could think of, about 300 bux worth so far. Are these carbs bullet proof or very much touchy?
I'm thinking that black sponge may have gotten sucked in and probably was really leaning out the mixture. |
theageofindustry wrote: Bulletproof. Clean it up, set it up properly and forget it. |
Posts: 10101 Location: seattle/athens |
![]() If that's some kind of black foam filter material(lower right) stuffed into the rubber intake, you need to remove it. If not, please tell us what it is. |
05 PX150, 66 SS180, 65 TV175, 74 Rally 200
Posts: 236 Location: South of I-66 outside the beltway |
matty5 wrote: theageofindustry wrote: Bulletproof. Clean it up, set it up properly and forget it. lynnb wrote: Thanks guys I'll order up the carb kit and filter. I did order a cable kit that covers the whole bike, along with all other wear items I could think of, about 300 bux worth so far. Are these carbs bullet proof or very much touchy? I'm thinking that black sponge may have gotten sucked in and probably was really leaning out the mixture. |
tyfun50 wrote: He was talking about the carby. |
matty5 wrote: tyfun50 wrote: He was talking about the carby. |
Yes I did remove the top to give a view of the inside of carb. I'll take it off strip the rubber off it and give it a good soaking in the kleen flo.
Here's the sponge that was in the hole and the wire mesh filter is just that and will also come out clean after a soaking
![]() ![]() the missing cover ![]() ![]() ![]()
Toss that foam and that wire mesh filter as it's not going to do anything. Replace it with the proper filter I linked to and be done with it.
theageofindustry wrote: Toss that foam and that wire mesh filter as it's not going to do anything. Replace it with the proper filter I linked to and be done with it. |
Why has no one mentioned that it is the wrong carb for a VBB? Should be a 20/17, not a 20/15.
It runs, It's a miracle?
Probably first things first, one thing at a time plus overload, I'd say. But OK... |
filmworker wrote: Why has no one mentioned that it is the wrong carb for a VBB? Should be a 20/17, not a 20/15. |
Posts: 5833 Location: Indo |
Lynnb wrote: filmworker wrote: Why has no one mentioned that it is the wrong carb for a VBB? Should be a 20/17, not a 20/15. |
koenig blues wrote: if u can change the fuel hoses as well mate good luck on the project and cheer |
SGN Scott wrote: Lynnb wrote: filmworker wrote: Why has no one mentioned that it is the wrong carb for a VBB? Should be a 20/17, not a 20/15. Thanks Lynn |
The spaco si 20.15 is according to sip is....
Main correction jet 140 Mixer tube be1 Main jet 83 Idle jet 42 Throttle slide 02 But if some of the more wiser members please chime in, i just am a cut and paste monkey and those numbers make no sense to me |
