Here's another tip I ran across that makes putting a lay shaft back together easier on a PX. After carefully getting all the needle rollers stuck into place using lots of grease, slip a noose over them made from a small tie-wrap and snug it up tight to keep them from going anywhere. When you install the shaft in the case it'll simply slide off the end as the shaft is pushed into the gear stack. Works like a charm.
