MP3 400
MP3 400
Hi folks,
I would like to replace the transmission belt by myself. Do I really need a pneumatic gun? I already have a torque wrench. Is it feasible to screw off the main bolt by hand?
Thanks in advance
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
with a torque wrench you need a buzetti tool to hold the vario
with a pneumatic (air) gun you need nothing else
@su-mac-dude avatar
MP3 400
@su-mac-dude avatar
MP3 400
I have a tutorial that lists the tools:
Belt Change pdf
You can use an impact wrench to remove the driven pulley nut.
But if you don't...
You can use a 21 x 23mm Deep Offset Wrench:
Craftsman 12 pt Deep Offset
Which is only $20
You will still need a variator holding tool to remove and tighten the variator nut.
MP3 400
MP3 400
WOW, thanks!
@fuzzy avatar
@fuzzy avatar
Operative word on the wrench is "deep" offset. Standard ofset won't get it. I had to order one from Sears as not a normal stock item.
@cagedodger avatar
NC700XD
@cagedodger avatar
NC700XD
If you're going to use pneumatic, look into getting some torque limiting extension bars.
@web-tech avatar
@web-tech avatar
If you are going to use these, read the directions and make sure the air pressure to your air gun isn't set too high
@cagedodger avatar
NC700XD
@cagedodger avatar
NC700XD
Read the directions sure, but the point of these is that the air pressure doesn't matter as much. Once you get to the torque that the bar is tuned for it just starts to wobble about and vibrate (it's basically a tightly wound spring) while it lets the impact driver fight against the resistance. The spring (extension bar) lets the impact hits unwind it enough to compensate for the set limit of the torque and snap back to formation for the next impact hit. I double check the torque against a torque wrench every few times and it's always within a few ft-lbs.
As always, use what you feel comfortable with (and this is key), just know that there are other options out there.
@vegasgeorge avatar
Homophobic Fuckwit
@vegasgeorge avatar
Homophobic Fuckwit
This is the set I picked up second hand:
@ramblerdan avatar
2009 MP3 400
@ramblerdan avatar
2009 MP3 400
Perfect! But make sure that the rust is metric, not SAE.
@scewter avatar
MP3 400
@scewter avatar
MP3 400
Can anyone tell me where I can get a metric Crescent© wrench?
Razz emoticon
John
@web-tech avatar
@web-tech avatar
Razz emoticon
John
I just happen to have an extra left handed metric one I can sell you, if that will work
Razz emoticon
John
to be an ass myself there is such a crescent wrench.
http://www.sears.com/shc/s/p_10153_12605_SPM5955820708P?sid=IDx20110310x00001i&srccode=cii_184425893&cpncode=33-106952260-2
@dailyrider28465 avatar
Mia Dolce II 2017 GTV 300, Ragazzo Vespa 946, Il Pazzo BV 350, & Mia Dolce GTV 250 -sold-
A good insurance policy and a felonious friend with a bazooka.
Nah, I'm kidding, just a funny thought.
[ Time: 0.0139s ][ Queries: 4 (0.0037s) ][ live ][ 339 ][ ThingOne ]
