After my last oil change, for some reason when I slow down at a stop light or sign my oil light will flash on 2 or 3 times then go off till the next time I slow down. Why would it do this? I constantly check the oil level and it's fine.
Sounds like a interesting case. I wish I had some good feedback for you? Did you check all wires? Is there a oil level sending unit that would be faulty?
In a car, this problem is usually due to sludge in the engine, blocking the oil return passages and causing slow drain back. It can also be a faulty oil pressure sending unit.
I would check oil pressure with a mechanical gauge first. If the pressure is good, replace the sensor.
All Content Copyright 2005-2025 by Modern Vespa. All Rights Reserved.
