Ok, my battery keeps dying and can't start the bike.
So far I have replaced the CDI and the battery.
I've checked the battery voltage at revs and its defo charging and been checking it after short journeys to make sure it's not the short journeys not creating enough charge and its not that and that the regulator is doing its job.
The culprit seems to be something in the system draining, as I checked it when I parked up at night and it had dropped almost a whole volt about 12 hours or so later.
So what can I do to check what is draining in the system ? Can it be a bad earth or something ?
