Is it just me, or does anyone else here get a little annoyed by the Torx and other security screw heads on your scooter? I'm used to slotted and phillips screws, or hexagonal bold heads. Now I'm forced to deal with Torx and those square hole thing-a-ma-bobs. Do you replace those screws, like on your battery cover? Or do you carry the Torx and other tools with you?
Re: A Bit Torxed
VegasGeorge wrote: Do you replace those screws, like on your battery cover? Or do you carry the Torx and other tools with you? |
Just like when they started using phillip screws rather than good old slotted, the torx can use more torque without killing the screw. It is actually a better screw. Especially it you want to unscrew something after several years.
Agree torx are better but what annoys me is when the use some of each should use one or the other.
The only Torx head bolts I recall on my ET4 are the ones that attach the flyscreen to their mounts.
They are a serious PITA. Two have already become useless, the problem being solved with a hacksaw, converting them for use with a plain old flathead screwdriver. The only security bolts I don't mind are the ones that fasten my license plate, which require a special wrench to remove. I haven't had to do a roadside repair that required me to remove my license plate. On the other hand, I would have to remove the flyscreen if I ever had to change my headlight bulb...A repair that's certainly plausible when on a road trip and something that can't usually wait (I always carry a spare bulb). I'll be converting or replacing all those flyscreen bolts when I get around to it. |
Posts: 23374 Location: Harriman, Tennessee, Tn |
I hate Torx bolts and replace them with a allen head. I don't wait for them to be removed either like during maintenace. The reason is if I'm on the road and need a tool I don't want to carry extra tools and if I need help chances are someone won't have one of those POS torx.
I've changed a couple. Fortunately I sometimes fix bikes on the side or buy and later part and have aquired some screws over time. I change them to allen hex. IMO they are better then torx since the socket is deeper.
I'm gradually changing all my torx bolts for allen bolts....easier to open and they come in groovy colours...........
Re: A Bit Torxed
jess wrote: AFAIK, it's only the bolts holding the exhaust, yes? Or are there others I've forgotten? |
Not that it matters but i prefer the allen and torx types to the slotted and phillips. The latter are old tech and get buggered up so easy.
Or we could go back to rope as our main means of fastening things together.... never did get a fid. |
If I had a nickel for every allen bolt I've buggered I'd have a bag of nickels.
Torx are much better heads. They guide the tool in better, so you almost have to insert it properly. They have much more contact surface so they take torque better and are harder to strip out. Go to a good hardware store and get some of these. I have one in metric Allen, one in SAE Allen and one in Torx. They are portable, easy to use, hard to lose and fit everything on the bike except the Phillips heads. Piaggio uses Torx because they're better. I like them a lot. P.
Handy
Dandy
Positive
camper wrote: Not that it matters but i prefer the allen and torx types to the slotted and phillips. The latter are old tech and get buggered up so easy. Or we could go back to rope as our main means of fastening things together.... never did get a fid. |
RIP
Oberlehrerhaft
GTS 250 w/ 43,000 mi
Posts: 1462 Location: Deceased, (MV member 2006 - 2014). |
I don't mind Torx and Allen heads and I prefer Phillips over slotted by far-all on the premise that I am wrenching at home.
My 07 GTS has Torx at the exhaust and the rear rack. Can't remember any others anywhere. Wait, the peep hole on the water pump, when you check the valve lash adjustment. I might change my view once I run into a roadside repair situation where I need a Torx key and don't have it. Right now I can only imagine that being a shredded rear tire, and in that case, I'm toast anyway because I don't carry spares. ⚠️ Last edited by Arno1 on UTC; edited 2 times
Reprehensible Misinformant
Posts: 7576 Location: Winchester, California |
Paul G. wrote: If I had a nickel for every allen bolt I've buggered I'd have a bag of nickels. Torx are much better heads. They guide the tool in better, so you almost have to insert it properly. They have much more contact surface so they take torque better and are harder to strip out. Go to a good hardware store and get some of these. I have one in metric Allen, one in SAE Allen and one in Torx. They are portable, easy to use, hard to lose and fit everything on the bike except the Phillips heads. Piaggio uses Torx because they're better. I like them a lot. P. Dare I say it...maybe there's a good reason they chose to use the fasteners they did, where they did? Hah! Maybe not.... Doesn't matter, having the right tools including a selection of Torx bits is half the battle since you'll find torx heads elsewhere including sporadically placed on other makes and model of bikes and cars. My DR650 has some here and there, as did my Mini Cooper S (big, beefy ones) so rather than gripe about them, I just tooled up for them just like I did when metric fasteners started infiltrating the garage. In fact I recently sold a bunch of SAE wrenches and sockets at a garage sale, after I dusted them off of course... Perfect excuse to head over to the Craftsman aisle at Sears! |
Re: A Bit Torxed
DougL wrote: jess wrote: AFAIK, it's only the bolts holding the exhaust, yes? Or are there others I've forgotten? |
gogogordy wrote: Dare I say it...maybe there's a good reason they chose to use the fasteners they did, where they did? Hah! Maybe not.... My BMW R1200R is entirely Torx, internal Torx and external Torx both. I haven't found a single non-Torx fastener on it. Thus, I carry an extensive set of Torx tools on that bike. It's having to carry around both allen and torx that is annoying. |
Posts: 46042 Location: Pleasant Hill, CA |
jess wrote: It's having to carry around both allen and torx that is annoying. |
I love torx fasteners. I got a little torx driver with bits to keep on the scoot. I also have a set of torx sockets that I keep in the garage. I've spent probably $20 on both.
As others have mentioned, they are a better fastener. |
Posts: 3721 Location: Babcock Ranch, Florida |
There are several advantages to Torx screws, but they are most important to manufacturers who can set up a work station with the proper tool for that operation. But when I am working on a bike I am taking apart many parts all of which have a different size Torx driver. So I need to have handy six or seven sizes of Torx where two Phillips drivers would fit almost every screw on the bike. And having a drive handle with torx bits is not the answer either because the socket for the bits is too large diameter to reach down in the wells in the plastic parts. I have to have actual single size drivers. And that of course increases the size of my road tool roll too.
Plus the average vehicle is not as uniform as the R1200R with only Torx. Most have some Phillips and Allen head thrown in for good measure. |
There are two separate discussions going on.
I'd set aside the security aspect of Torx bolts. Now that the drivers are commonly available, there is no security aspect. Are Torx better than flat or Phillips? Probably yes. Are they still a pain? For me and for others, based on the responses, yes. There's not a lot I can do about uncommon or very involved maintenance, but I'd like to carry as few tools as possible to effect common roadside repairs. I already had three different size Torx drivers, and none of them fit the bolts on my flyscreen. Just for my ET4, I have to carry a socket set, Phillips and flathead drivers, hex wrenches, and now, Torx drivers when I touring. I keep the space down by only carrying the sockets and hex sizes I think I'll need. Still, I like Paul G's suggestion...It looks like the best way to go. If you gotta have them, have them all, and in as small a package as possible. And as always, there's always roadside coverage to take care of the everything else. |
tomjasz wrote: I'm often pissed when I can't find fastener sizes I need in torn. Hurry the F up. And yes two or three head types on one machine is insane. And very Italian IMO The days of repairing a bike or car with a big screwdriver, a hammer, some vice grips and duct tape are long gone. P. |
2006 GTS 250ie in Silver
Posts: 1814 Location: Bend, OR |
Does anyone have a link to a site that sells anodized bolts. I have found Ano Ti bolts that are Torx but they are $$$. Red or Gold bolts in the brake rotors would look sweet.
RIP
Oberlehrerhaft
Paul G. wrote: tomjasz wrote: And very Italian IMO |
The GTS has all sorts of different size Torx, Allen and Phillips heads. For that reason the only tools I carry are a mobile phone and credit card.
bendcyclist wrote: Does anyone have a link to a site that sells anodized bolts. I have found Ano Ti bolts that are Torx but they are $$$. Red or Gold bolts in the brake rotors would look sweet. or the US site.........http://www.probolt-usa.com/ |
Can anyone tell me what size the torque screw is for a battery cover and knee pads of a 2012 300GTS?
bbeckes wrote: Can anyone tell me what size the torque screw is for a battery cover and knee pads of a 2012 300GTS? |
Posts: 8758 Location: Annapolis, MD, USA |
Paul G. wrote: tomjasz wrote: I'm often pissed when I can't find fastener sizes I need in torn. Hurry the F up. And yes two or three head types on one machine is insane. And very Italian IMO The days of repairing a bike or car with a big screwdriver, a hammer, some vice grips and duct tape are long gone. P. |
