@masala avatar
@masala avatar
946
I want to buy a wrench specifically for this application. Is it a 24mm or 25mm nut on the outside of the plug?
Thanks!
GtS 300 super
GtS 300 super
24mm. I would recommend do a search on YouTube for DIY oil change in Vespa gts.
@glasseye avatar
@glasseye avatar
24mm
R
@masala avatar
@masala avatar
946
Thanks.
I've done oil changes x3 already on the Vespa - just always used an adjustable wrench to get the plug off. This last time it was oriented in such a way that I just couldn't get a good "hold" on it, and caught myself wishing I had a properly-sized box end wrench to do the job.
did an oil change this afternoon on my gts 250, its 24 Metric
gts300
gts300
I use a 24mm ring spanner
@super-fly avatar
Vespa GTS300ie
@super-fly avatar
Vespa GTS300ie
24mm shallow 6 sided socket
@andyscooter avatar
Vespa gt200
@andyscooter avatar
Vespa gt200
i have a specaily made 24mm spanner
i cut it down so it does more then 1/4 turn each time
I'm going to be the contrarian here. It is 24mm, but a 15/16" socket (or wrench) is just slightly smaller, and fits on the oil drain plug with slightly less play.
Generally speaking, 24mm and 15/16" are interchangeable.
@sdg avatar
GT60
@sdg avatar
GT60
This exactly. ^
SDG
@arno1 avatar
Oberlehrerhaft
GTS 250 w/ 43,000 mi
Oberlehrerhaft
@arno1 avatar
Jettin makes a tool for this and the hexagonally-topped filter. It is the red one in this image:
Made of aluminum and therefore not the strongest material for such an application, but with proper handling it works. I have one.
(Image lifted from CanuckSkoot's thread.
@tomjasz avatar
Grievance Farmer
Grievance Farmer
@tomjasz avatar
This exactly. ^
SDG
One of 3 Snap on tools in GTS kit. 15/16 short handle 6pt.
[ Time: 0.0080s ][ Queries: 3 (0.0018s) ][ live ][ 339 ][ ThingOne ]
