I was hoping someone could help me diagnois a strange problem I am having with my scoot. I was out for a ride and while going up a significant uphill grade it suddenly lost power. I pulled over to the side of the road and my scooter stalled. It started back up and continued on without any more problems. Since I recently filled the gas tank, I initially thought it might be a fuel/carb problem and that bad gas was probably the culprit. I have since replaced the gas. I went out riding again today for a long ride. On my way home I went up another big hill and experienced the same problem. Scoot started to slowly kind of bog down. I'm thinking it might also be a transmission problem. It just kind of slowed down and stalled when I got over to the side of the road. Again, it immediately re-fired and ran again without any problem. Very confused! Anybody have any similiar experiences or thoughts?
Arno1 had a similar problem on hills. If I recall, it turned out to be a problem with the spark plug lead. Something about going up hill and the way it loaded the suspension. It was causing the wire to become intermittent. Easy enough to check.
All Content Copyright 2005-2024 by Modern Vespa. All Rights Reserved.
