sand, prime, paint.
if you don't like your work, you can always buy new ones. (imho, i'd keep the rims it came with.) i've pained rims, it's soooo easy. |
yep . . . like auntie said.
make sure you do the inside too. or get them blasted & powder coated which is what i prefer. |
Those are good for another 50 years. Have them blasted and then powder coated. Don't fall for any of that tubeless nonsense. They are a pain in the arse and not worth the returns IMHO. I'll take a good old fashion tube, rim with a modern compound tire every time. I'm cool with modern carbs, expansion pipes, modern ignitions and other trick shit though.
jamesjohn wrote: blasting and powder coating will cost twice the price of brand new. theres a local company here who does good work for a decent price. the thing with powder coating is that it'll last longer than paint & is tougher so is more durable & less easy to damage. powder coating for me all the way. with the amount of time it'll take the OP to strip & sand and the cost of the materials to prime & paint (not to mention rust treatment), powder coating wont seem overly expensive giving that it'll last a lot longer. |
Check Scooter Mercato. Running deals on tires/tubes/rims combo.
Under $120, might qualify for the %25 discount he is running over the weekend. |
jamesjohn wrote: blasting and powder coating will cost twice the price of brand new. |
After spliting the rims.. The rust on the inside was very bad... I expect one will make a good spare.... I order two from Scooter Mercato..... Thanks for all input
jamesjohn wrote: blasting and powder coating will cost twice the price of brand new. And by the way, that is mostly surface rust. But go ahead and waste your money if you want. |
1977 Vespa P200E, 1972 SIL Lambretta GP 150, 1975 Lambretta LI 150 Special
Posts: 121 Location: Dallas |
To be more precise, buy a wire brush wheel for your electric drill, spend 20 minutes going after the outside of those rims with the wheel, and they will look new.
Next: spend even more time knocking the rust off of what will surely be a mess of corrosion on the inside of the wheels with the same wire attachment. Prime. Paint. Works every time. You'll be set, all for about $12 bucks worth of supplies. |
Primasarah
1979 P200E, 1977 Rally 200, 1974 Primavera
Posts: 3087 Location: Lake Worth, FL |
rgconner wrote: Check Scooter Mercato. Running deals on tires/tubes/rims combo. Under $120, might qualify for the %25 discount he is running over the weekend. |
Primasarah
Speed_Kills wrote: jamesjohn wrote: blasting and powder coating will cost twice the price of brand new. And by the way, that is mostly surface rust. But go ahead and waste your money if you want. |
RIP
T5s
Posts: 17005 Location: The West Of Yorkshire ... Gods Country |
1980 p200e, 2005 Stella w/ Sidecar, 2006 Triumph Scrambler
Posts: 428 Location: Chicago |
I sanded mine down, primed and painted them with Rustoleum. It's not as durable as the original finish or powder-coat, but I can do touch ups in a jiffy.
They are pretty. |
TravisNJ wrote: Speed_Kills wrote: jamesjohn wrote: blasting and powder coating will cost twice the price of brand new. And by the way, that is mostly surface rust. But go ahead and waste your money if you want. |
Primasarah
the rims I got new were Piaggio stamped, and were $25 each. And they replaced the original rims that i used the wire wheel, sandpaper, rust treatment, primer, and paint. that just ended up rusting again anyway.
the knowledge that my new rims were safe and looked good certainly justified the cost and time saved. for me anyway. I dont fault anyone going one way or the other. but Speed_Kills, I guess you feel differently huh? |
No it's cool. I guess I just don't get why anyone would trash a perfectly good item.
BTW, just because they are stamped Piaggio does not mean your rims are made in Italy by Piaggio and that they are safe. Maybe they are fine, maybe they are not. I can not vouch for either. But hey we are not really talking about your rims here are we? Im just giving the OP my opinion on his rims. Maybe we should start a new thread on your Piaggio stamped rims? |
Speed_Kills wrote: No it's cool. I guess I just don't get why anyone would trash a perfectly good item. BTW, just because they are stamped Piaggio does not mean your rims are made in Italy by Piaggio and that they are safe. Maybe they are fine, maybe they are not. I can not vouch for either. But hey we are not really talking about your rims here are we? Im just giving the OP my opinion on his rims. Maybe we should start a new thread on your Piaggio stamped rims? |
Quite frankly I have never seen a set of rims fail. So who cares really.
Personally I would rather spend the $20-25 extra dollars and have a better, longer lasting product in the end. Can anyone here dig that? |
RIP
Speed_Kills wrote: Quite frankly I have never seen a set of rims fail. So who cares really. Personally I would rather spend the $20-25 extra dollars and have a better, longer lasting product in the end. Can anyone here dig that?
Posts: 6897 Location: GT, Texas |
To avoid making tough decisions like this, when my rims get rusty I just pour gasoline over the entire scooter and light it on fire.
RIP
rufio wrote: I think Jackson did that |
74 Rally 200, Inian GP 200, Li 150 and 100 Sport
Posts: 184 Location: Ontario Canada |
If you paint them, they will scratch to shit. Powdercoat works best.y guy in town does great work and only charges 20.00 for color of your choice and blasting
In a couple hours I am taking three sets of rims and other small parts to get powder coated. There is no denying that it is more costly than simply replacing these parts but, in the long run, I think it is a better solution.
(The parts are all for a Rally and a Lambretta.) |
Hi All,
I recently dropped off my OEM rims and center stand w/brkts. at my local Powder coater. I'll followup with before and after pics and costs. Films at eleven...... |
Re: rims... Paint?
T5bitsa69 wrote: did once ..... long story .... dont use turps |
I wire brushed the original piaggio rims on my scoots. primed+painted (rattlecan). stainless washers and nuts.
new rims that I've purchased have had the chrome or paint chip off within a year and tend to bend easily. |
