Any idea what these are for?
Top 2 are the same, bottom one is thin as.
Bottom one is thin, like a shim
WP2 wrote: I'm going to say clutch spacers, and a hub seal. Could be wrong though. |
the top two look like fork bearing races. do they have a lip on them?
the bottom, since thin, then I would guess a washer in the front hub. just guesses since I dont know dimensions. |
RIP
I'm not sure.. are the top two flat? or do they have a little lip? hard to tell in the pic..
They'd have a slot for woodruff key if they were clutch spacers.. at least p/px clutches. *I'm not sure about older motors/clutches though |
Posts: 5109 Location: west aus |
RIP
85 Vespa PX150E with sidecar, 80 P200 with sidecar, 96 Goldwing with Hannigan Sidecar, LR87aj5, LR91aj3
Posts: 580 Location: Central Washington State |
RIP
Rob98801 wrote: Vader19 wrote: figured it out.. disregard. |
No lip.
jamesjohn wrote: the top two look like fork bearing races. do they have a lip on them? the bottom, since thin, then I would guess a washer in the front hub. just guesses since I dont know dimensions. |
Re: PX200E - Engine - Spacers
Top 2
OD - 42mm ID - 28mm 2mm thickness Bottom one OD - 36mm ID - 22mm 0.5mm thickness (approx) From a PX 2001 model I believe. Thank you for all the ideas and suggestions. Very much appreciated! kt wrote: Any idea what these are for? Top 2 are the same, bottom one is thin as. |
I think you are correct!
scootermarc69 wrote: The top two look like the washers that go behind the engine mounts. |
Posts: 6897 Location: GT, Texas |
I always take dozens of photos when I do anything but they got corrupted.
So I am left with nothing. astromags wrote: scootermarc69 wrote: The top two look like the washers that go behind the engine mounts. |
