@scotfree avatar
@scotfree avatar
Hey guys.
Just got my first Vespa a couple months back and I have (what's probably) a stupid question:
Does anyone have any advice on how to fill my tank without overflowing? Any tricks/indicators? Or is it just a question of knowing the gauge and how much gas I'll need.
Thanks.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Here is an article from our wiki that has instructions and pictures to help prevent overfilling and subsequent spills. You don't indicate in your profile what you have for a scooter, but I am presuming it is a modern Vespa.
FAQ: How can I avoid overflowing the gas tank?
⚠️ Last edited by NightWing on UTC; edited 1 time
@megatitaniumman avatar
Vespa ET4 150, Ebony.
Here?
Where?
GTS 300 Super
GTS 300 Super
almost there
New Owner Questions
@scotfree avatar
@scotfree avatar
Thanks, Shooter.
@kruella_dv avatar
Piaggio Beverly Sport Tourer (BV350)
@kruella_dv avatar
Hi Scotfree. There's no such thing as a stupid question!
Regards, John W.
@muttsnuttsracing avatar
GTS 300 SSR
GTS 300 SSR
Another handy hint someone here said....... is when you unscrew the filler cap, raise the back of the pet carrier and place the cap vertically to hold the carrier up. Then should you over flow it won't fill you pet carrier with fuel and you won't leave you filler cap on the petrol pump as you drive off..........works for me
@joedevola avatar
2009 Vespa LX150ie, 2007 GTS250ie, 1982 Honda CB900F, 1989 BMW K100RS
@joedevola avatar
Oh, and by the way, when you see people here refer to the 'pet carrier', they are referring to the black plastic under-seat storage tub.
@crazycarl avatar
@crazycarl avatar
The main thing to keep in mind when filling is that it is quite small compared to even a compact car. Fill your tank slowly without using the pump handle lock (not sure what that's called that holds the pump open).
A little field research will go a long way as well. Find pumps at gas stations where the fuel flow out of the pump is easily modulated for very slow flow. There are certain stations I avoid simply because the the pump handle is quite stiff to operate or the overflow sensor is very touchy.
I've only overflowed my tank twice in nearly 8000 miles by following directions in the WIKI listed above and paying attention to the task at hand. Of those two overflows, one was flat out user error...the other a faulty shutoff that did not work correctly at an unfamiliar station.
As with most things scooter related, practice makes perfect. Get out and ride!!!
'05 Vespa Granturismo
How to fuel a Vespa without overflowing it.
1. Raise the pet carrier with the fuel tank cap.
2. Fill it slowly. It isn't going to take much.
3. Watch what you're doing.
That's how the pro's do it.
@justjosh avatar
2012 Vespa LVX 150
@justjosh avatar
2012 Vespa LVX 150
I've settled upon the following sequence:
Wait until gas light is solidly lit
Take pet carrier out, or at least prop it up with the gas cap
Fill tank with 1-1.5 gallons
All of my attempts to find a gas station with a safety click off that works for me have failed, so now i just put in a known quantity.
@andyscooter avatar
Vespa gt200
@andyscooter avatar
Vespa gt200
i cant believe you all have so many problems putting fuel in a vespa
in three vespas i have never overfilled
and wouldnt it be better if you left the pet carrier in as that fuel is then dripping onto a possible hot engine rather then into a container
Andy - US pump nozzles are different from UK ones. First, very few can be modulated with any accuracy, they tend to be ON and that's it. Plus in California and some places elsewhere they have the daft 'foreskins' that have to be held open with one hand while the other operates the trigger, and they obscure the view down the filler neck.
It's miles easier and a no-brainer almost anywhere else but the US, where it's damn hard to fill to an optimum maximum. And deity help you if you do overfill, unless you ride off straight away, the Evap Crap will choke on the excess run-off, and give poor starting and running.
@sharpcolorado avatar
2012 GTV 300 & LXV 150
Here's a pic that might help:
Does someone in Europe, specifically Italy, have to worry about overflow, or is this problem specific to the U.S? In other words, can I trust an Italian pump to shut off in time?
Thanks.
In the EU, including Italy, the pumps shut off just fine - on some models often with room for quite a bit more, which you can do as slowly as you like. No evap crap worries if you do slightly over-fill doing a 'top-up' either.
@masala avatar
@masala avatar
946
If you tend to run with your pet carrier absolutely empty, the yes. Many people, I suspect, routinely keep stuff in there (towels, change of gloves, visors, miscellaneous other $#!t) and they want to keep all that stuff gas-free. It's easier to just raise the carrier, in that case, than take all the junk out at every fill-up...
Thanks, one less thing to worry about
Just a suggestion, but maybe the Wiki should state which countries this is an issue in? At the moment, the Wiki effectively says that this is a Piaggio/Vespa design defect that affects filling the tank in all countries. If what some of the people on this thread are saying is true, the Wiki is wrong. In fact, had I not thought to ask the question, I would not have known that the Wiki is apparently wrong, not only in Italy, where I am currently residing, but with respect to the whole of the EU.
@quentin avatar
Red GTS250
@quentin avatar
Red GTS250
that is the un-patented Q- Manoeuvre, t'was I
@tb avatar
@tb avatar
1+ I'll wait until 1/4 tank then fill to 1.5 - 1.7 if using an unfamiliar gas station and not sure about auto shut off.
However, since I go to one station and the auto shut off works:
Remove the pet carrier (feel safer, just in case of any splash back)
Fill with nozzle facing rear of scoot...nice gradual flow
Once it clicks I'm done...no topping off!
On a related subject...always be careful when you plant your at a gas station. Gas spill residue is sometimes hard to see when it dries up but leaves a film...I had a little slip and was able to regain footing...not a pleasant feeling! Then you go and inform the attendant and hope that will go out and clean.
I wait until it clicks off. Guess i have good luck but i tend to use the same gas stations. Be careful to not overfill. Gas will get down in the brake light housing and eventually cause it to crack. easy fix but not so cheap part. Particularly true on the LX models.
Vespa 300 GTS SS
Vespa 300 GTS SS
Filling up
For those in California and having to use the goofy nozzle system, Aerostich has a nifty piece that slides on the nozzle to hold back the rubber cover part which allows easier filling.
I live in a part of California that requires all of the service station fuel dispensing hoses to be equipped with the vapor recovery boot on the dispensing nozzle. When fueling a scooter, the boot must be retracted with one hand in order for the fuel to flow.(When fueling an automobile the nozzle is pished into the receptacle to a depth that retracts it). It seems to me to be a simple matter to retract the boot with one hand, gently modulate the fuel flow with the other hand, and watch for the tank to fill. It is obviously considerably more trouble than filling an automabile, but, after all, you're only going to put about two gallons in. What the hell!
I will admit, it must be a real bitch for anyone handicapped without two hands.
Some of our requirements out here in California can be a real pain in the
---, but, boy, we sure have a lot of really good looking girls out here.
I've never found a US pump that can be 'gently modulated' - at least not in the sense that those in the EU at least can be. The US ones have a 'kick on' feeling - an initial gentle squeeze to allow fuel to dribble out is impossible.
GTS 300 Super
GTS 300 Super
The pumps are quite controlleable in New Zealand but the issue can be that the dial spins around so fast due to the price per litre.
Despite that...I sometimes play the silly game of trying to get it to dispense 1 or 2 cents worth of fuel to round the price to the whole or half dollar.
We have dollar rounding in NZ so $3.98 would be $4 for example.
(we dont have 1 or 2 cent coins but oddly...prices can be marked as $1.99, $99.98 etc..)
Dispensing 1 cents worth is real difficult but 2 cents is doable.
Thanks for my smile of the day
jimc,
Let's face it , Jim. Some guys have got it and some aint!
@tor2ga avatar
@tor2ga avatar
You give me great hope for the next several years. Laughing emoticon
@binkiewinkie avatar
Vespa GTS 300 SUPER
Vespa GTS 300 SUPER
Thank you for the picture I could never visualize what everyone was talking about with lifting the pet carrier and putting fuel cap.
@maniac avatar
2013 GTV 300 IE
@maniac avatar
2013 GTV 300 IE
If a station has paper towels, I wrap one around the gas opening.
Then pull back on the sleeve as I pump, occasionally stopping to check to see the level of gas. Continuing to pump until it is close to the top....
I'm considering replacing the instrument cluster with a digital.
Tired of the flashing low fuel light and 5mph indication when idle....
Maniac
@undertoker avatar
Gts300ie
@undertoker avatar
Gts300ie
I find it varies from garage to garage
Some of the fuel pumps absolutely hammer the fuel out really fast, while some pumps are just a trickle.
As such I tend to put the pump nozzle in as straight and as deep as possible into the tank, then I kinda just trickle it in near the end of a fill.
I got fed up with gloves, neck cover and goggles stinking of petrol after the first novice refuel that covered the lot in unleaded....
Crying or Very sad emoticon
@heels_on_wheels avatar
GTS 300 Super Sport
GTS 300 Super Sport
Easy to overfill here in Australia too so after my first spill I was straight on this forum and have now adopted the cap in PET carrier technique and it's been fantastic!!!
@lx125man avatar
Vespa LX 125
@lx125man avatar
Vespa LX 125
When I first got my lx, I was unaware of how inaccurate the fuel gauge was so I overfilled.
I now tend to wait for a steadily lot fuel light and slowly put in around 6 litres.
The book states I have a tank capacity of 8.5l
@lx125man avatar
Vespa LX 125
@lx125man avatar
Vespa LX 125
*lit
I just fill mine every 200km. Thats about 7L and another 40-50km if I forget.
When it gets really low the fuel light starts to blink when you hit a bump...
I have put 8.5L in mine once so the tank is at least that big.
@lx125man avatar
Vespa LX 125
@lx125man avatar
Vespa LX 125
Oh I don't doubt the size, I've got 8l in once but just don't want to take the chance any more so I'm happy with 6l fill ups
@rusty_rope avatar
Vespa GTS 300 Super
@rusty_rope avatar
Vespa GTS 300 Super
So i'm the only one who buys 10 litres of petrol at a time in jerry cans and fill up when low?
To be fair though, the flys tank is low in the foot well and almost always i over fill when at the pump as i can't see anything.
@xine avatar
LX150
@xine avatar
LX150
Ah, this may explain my experience. I waited until the gauge read a hair or two over empty -- but the light had not come on -- and was surprised that the tank only took 1.25 gallons, when it is supposed to be over 2 gallons. So if the gauge is unreliable -- is the low fuel light reliable enough? Or should I get used to just adding 1 gallon at a time?
@lx125man avatar
Vespa LX 125
@lx125man avatar
Vespa LX 125
I have found the light very good. It will flicker for a while and eventually stay on solid.
You can do a few more miles from here on bit it's up to you how far you push it, I played that game and lost lol and had to push to the petrol station (luckily only a few mins walk)
I'm not fussed about filling it to the top anymore so I do as I said above
@rangeraj avatar
2011 300GTV
@rangeraj avatar
2011 300GTV
I tend to fill my tank slow and easy, and I listen for the tell-tale sound of the gurgling as it approaches the neck.
Some of the pumps I have used don't click off, and this is how I keep from overfilling.
[ Time: 0.0298s ][ Queries: 4 (0.0220s) ][ live ][ 343 ][ ThingOne ]
