@romild0 avatar
P 200 E, GTS 250ie, GTS 300ie
@romild0 avatar
Hi friends of old Vespa
I'm a proud owner of P200 E. Recently, my Vespa started to produce a strange "aluminium" noise, here is the video that I made for this opportunity:
At 1st this sound started to get out after machine got worm, but after a while, this sound is present from the second i fire up my vespa.
I already took Vespa to the local mechanic but did not find anything - not outside nor inside the engine. When I drove off, the noice was again present after around 10km of driving.
Otherwise there is nothing wrong with the machine, it runs smooth, only this noise is annoying. I also made already around 100+ km with vespa in this condition, so I guess it's nothing critical.
Any advice or suggestion is welcome.
Thank you
74 Rally 200, Inian GP 200, Li 150 and 100 Sport
Sounds like the flywheel rubbing on the cover or the cylinder shroud is loose
@saturn avatar
AmeriBodge
@saturn avatar
AmeriBodge
yep. sometimes the cover is bent just enough that the fins from the flywheel graze it and make a scraping sound.
@romild0 avatar
@romild0 avatar
Thanks for the reply guys, but... I removed the cover + cylinder shroud but the sound is still there
@saturn avatar
AmeriBodge
@saturn avatar
AmeriBodge
it's hard to tell from the video.
could be any number of things. does the noise go away when you squeeze the clutch?
@romild0 avatar
@romild0 avatar
That was my 1st try but no.. The sound is non-stop present, no matter what i do
@arpark avatar
Stella
@arpark avatar
Stella
So you've already eliminated a few things. Since its not in gear it has to do with either the flywheel rubbing elsewhere (more likely) or the piston (but i say that's unlikely but possible since it's running well).
Does the sound increase in frequency or pitch when you are driving it? Turn the fly wheel by hand and see where in the stroke it is happening. Maybe that could give a clue.
@rob98801 avatar
85 Vespa PX150E with sidecar, 80 P200 with sidecar, 96 Goldwing with Hannigan Sidecar, LR87aj5, LR91aj3
@rob98801 avatar
MY swag...
Something (stick, small pebble, dirt) at, behind or around the flywheel.
AIr intake at the carb?
Compression leak?
leak in the exhaust system?
@saturn avatar
AmeriBodge
@saturn avatar
AmeriBodge
I still think it's something rubbing
but I would check the torque on the flywheel (or completely remove it and look for scuffs)
also check the play on the crank itself -- see if you can wiggle the flywheel up and down or side to side (with the scooter NOT running) -- this would be an indication of a worn out bearing and you should fix it ASAP to prevent damage
could also be a head leaking or a loose spark plug...
REALLY hard to tell from a single youtube video
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
Take the flywheel cover off and start the engine. In fact, just start removing stuff until the problem goes away. Ha!
'79 P200E
'79 P200E
Crank rubbing on the case due to worn crank bearings?
Grab the flywheel and try to move it left, right, up, down, in, out to see if there's play. Oh, and sing the Hokey Pokey while doing it. Seems to make a difference.
You can also drain the oil and see if there is grit in there.
Hate to be a pessimist.
@rob98801 avatar
@rob98801 avatar
Have we found out anything?????
[ Time: 0.0122s ][ Queries: 3 (0.0029s) ][ live ][ 335 ][ ThingOne ]
