Hi,
I'm new to the forum. I have two vespas, a 2003 PX200 which has never troubled me and a 2002 ET4 125. The ET4 is a recent purchase and has just about got me beaten with an electrical problem.
It starts and runs fine from cold, but after riding for a short while, it will not start again after it has been turned off. It will wind over but not fire.
B
Initially I thought this may be a fuel problem so have stripped and cleaned the carb, un-siezed the accelerator pump, reassembled and adjusted mixture and it runs very well now but still will not start from hot.
The problem is definitely ignition related as I have pulled the plug cap off and put another plug in it to see if it sparks and it does not. But if I leave it an hour or so and try again there is spark. Put the cap back on and it fires up and away I go again.
I don't know if this problem could be related to immobilizer or not. The scooter only came with the one black key but I would expect the immobilizer would not allow it to start at all if that was the problem.
Most times this has occured it has been after a short ride and after I have turned it off and gone to start again after a few minutes. No go. But it has also stopped on its own, once after I'd ridden about 15 minutes and was idling at a set of lights and it died and would not start again and another time after only about 5 minutes riding and while under acceleration it just cut out and died. I came back an hour later and started up and rode home.
The recurring theme here is that this scooter lulls me into a false sense of security and then leaves me stranded on the side of the road. Its driving me !@**! NUTS
Any ideas anyone?
Toby
