Hi Guys
Need your help in trying to find the problem to the following;
Just re-built my Rally 200 engine and driving around the suburbs on short 10 min trips the engine runs great and accelerates hard. I therefore decided it was time for a test run on the open road.
1) As soon as I reached 80Km/h the bike started to jerk as if it was running out of fuel. I swung the tap over to reserve but the jerking continued.
2) The jerking lasts for a few seconds and then the engine pulls for say 5 to 10 seconds and then jerks again.
3) Engine sometimes died, bike coasted for a say 5 to 10 min and then engine starts up again
4) Initially, keeping the speed under 80km/hr the jerking disappeared. However towards the end of the ride the jerking got worse and started at around 50km/hr
5) On 2 occasions during the ride when the bike starting jerking I pulled the clutch and the engine revved extremely high with the throttle closed
6) When I got back home I drained the gearbox oil to check for fuel in the oil. I could not smell any fuel but the oil was extremely black. Scoot has only done about 50km since last oil change.
7) Popped headlight low beam bulb and brake light on ride
8.) Recently converted to 12V Ducati ignition
9) Stock cylinder
10) Carb 24/24E, running a 118 main jet. Did a plug chop in the suburbs and think I am running slightly rich, dark brown color on plug and oil splats from exhaust on rear wheel
11) Fuel tap is a SIP fast flow tap, I was planning on kitting the bike and had to replace fuel tap recently and therefore went for the fast flow.
12) On the short trips round the suburbs the bike really ran great; I am thinking that the problem surfaces when the engine gets hot. I will take the scoot out in the morning with a cold engine. Almost certain that I did 80km/hr in suburbs with no jerking.
