1962 VBB
1962 VBB
I recently rebuilt a 1962 VVB motor and I am having a starting problem that is really baffling me. Here are my observations/facts:
- When I got the bike running one time yesterday, I had to kick more than 50 times.
- I can't get the motor restarted after the first fire up.
- I have strong sparks.
- Choke is on when kick.
- Mixture screw is set at 1 1/2 turned out from close.
- Idle screw turned out 2 1/2 turns from close.
- Brand new carb.
- I get occasional loud backfires from the exhuast when I try to restart. The motor still would not start.
- I see a mist of fuel coming out of the carb intake when I crank
- I see the same mist when I did get the motor running.
- Compression is good.
Lastly, when I did the compression check by placing my finger in the spark plug hole then cranking, I seem to get just plain air. Shouldn't I get aersolized petroil instead?
I'd appreciate your feedback. Thanks!
@mirror-fx avatar
'77 P200e
@mirror-fx avatar
'77 P200e
Make sure you don't have any gas leaks into/from the carb that'd stop fuel flow.
Take a straw and put a bit of gas directly into the carb above the air mix screw (I recently did this with my Del'Orto, never worked with anything else, so I apologize if that moots the procedure entirely) and kick it a few times.
I had to do this with my air filter off, which scared the bajesus out of me while working outside, but it worked out. By doing this you also get a clear view of your choke pulling, ect. If your air filter is all mucked up after all that kicking, you may have a flooding problem, or just an issue with the fuel not getting pushed where it should.
Pull the flywheel and see if the woodruff key sheared. Double check your timing.
@music avatar
many
@music avatar
many
Also double check the jets to see if they are really clean.
Even if you have a new carb, you could have some crap in
the tank that plugged a jet.
Rob
1962 VBB
1962 VBB
Thanks for the sugestions.
Mirror-Fx, I have been cranking with the air filter off. I will try the straw trick.
Early rejecter, I check the flywheel operation and there doesn't seem to be anyhting that would indicate a broken woodruff key. However, I don't know how the timing is set on my motor since I don't know how. Would incorrect timing severaly affect starting issues. I mean, when I crank there is no sign of combustion.
I am also wondering about the lack of petroil mist in the combustion chamber. Is is possible that I installed the piston wrong or have blockage in the transfer ports, etc?
'79 P200E
'79 P200E
is the plug wet? Plug wet = getting fuel. then you have an ignition or timing problem. Plug dry = jet plugged or other fuel related issue. Isn't there an arrow or something that points to the exhaust port?
It certainly can. You'll need to check it. There're instructions here:
http://www.scooterhelp.com/tips/timing/points.timing.html
Min wrote:
I am also wondering about the lack of petroil mist in the combustion chamber. Is is possible that I installed the piston wrong...?
If you're getting backfiring, something must be getting in. It is possible to install the piston incorrectly -- there will likely be an arrow at the top of the piston; it should be pointing towards the exhaust port on the cylinder. I'd set the timing first; if you still have starting or poor running issues after that check the piston if you think you may've installed incorrectly.
@bar_italia_classics avatar
1974 Rally 200, 1977 Rally 200, 1958 LD125 Mk III, 1965 S.S. 180 and on and on
+1 on spun flywheel/points/timing problem.
Also, suggesting that one put gas directly into a a backfiring motor is a very very dangerous proposition.
1962 VBB
1962 VBB
Sounds good, I will try setting the timing first.
So, if I somehow got the motor to run before, I can safely assume that I am getting something to combustion chamber?
It's hard to tell from looking at the spark plug. When I got it up and running before, the tip looked dark. The tip stayed clear since yesterday when I could not get the motor to strat at all.
I vaguely remember paying attention to the arrow and orienting it towards the exhaust side.
@sfvsr avatar
a lambretta or two
@sfvsr avatar
a lambretta or two
Re: Yet another starting problem
There isn't really a "setting" for the throttle stop screw.
1962 VBB
1962 VBB
Here is an update. As many of you suspected, it was a timing issue. Specifically, it was a sheared woodruff key that grossly offset the timing. Good job, Early Rejecter! The motor now starts on 1-2 kicks and idles great.
Now on the next problem. I don't know if this indeed is a problem. I just don't know. How does shifting of gears work in a Vespa motor? Am I suppose to be able to shift through all gears at any given time when the scooter is stationary? Or do I need to be moving in order to shift to some gears? I can't seem to shfit through all gears with the bike not moving.
Thanks,
Min
@jamesjohn avatar
1970 Vespa Rally 180
@jamesjohn avatar
that is normal. the only shift at a stand still is from neutral to 1st.
1962 VBB
1962 VBB
Good to know!
[ Time: 0.0135s ][ Queries: 3 (0.0048s) ][ live ][ 318 ][ ThingOne ]
