Vespa PX 200
Vespa PX 200
⚠️ Last edited by peartree on UTC; edited 1 time
Vespa PX 200
Vespa PX 200
Pressure switch/sensor
@klaborde avatar
@klaborde avatar
Re: Tilt lock pressure switch/sensor How to change ?
peartree wrote:
Hi, my pressure switch/sensor is leaking fluid leading to the alarm to sound 5 times. Have cleaned switch a couple of times work,s for awhile before fluid leaks back. What i would like to know is when you remove switch/sensor
to replace, will fluid leak out ! do you need to bleed system.
My MP3/250 had what the Dealer thought to be a bad one.
My horn blew as you stated...
From what I remember, they just loosened the Nut and replaced it.
But when they were done, they added more DOT4 and did a bleed of the system. I don't recall while standing their if a lot of fluid came out. The Dealer at the time was working on an issue where my bike would loose pressure and lean to one side. It was eventually determined to be the Master Cylinder where it would actually loose pressure and the fluid would leak back into the reservoir as I had no leaks which made it hard to find the root cause.
Keith,
Marietta, GA
Vespa PX 200
Vespa PX 200
[ Time: 0.0091s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
