When I'm driving along I can see the headlight flicker super-bright occasionally, especially at high rev's and when I go over a bump. In the past week I've blown two headlights and just today the left indicator lights.
Can someone help with some assumptions...
Assumption 1) Headlights are AC and won't be blown by issues with the regulator (stop worrying about the regulator that I recently had installed because the old one wasn't charging the battery?)
Assumption 2) Bumps causing change in brightness isn't much of a clue either as you'd expect a short to cause dimming?
Assumption 3) The fact that they blow when I'm doing about 70kmph/45mph is a key clue. (I just don't know what it suggests!?!).
Any help would be appreciated. Cheers.
