The walk thru is separated in 3 parts:
1. horn disassembly
2. Air horn/relay mounting and airhose connection
3. Nozzle mounting
Note: the wiring is not shown as there are plenty of threads on proper wiring, points to remember:
1. run 10 to 14 gage wire from battery to relay. I used 10 gage since I'll be drawing the power for heated clothes.
2. Use female spade connectors + wire shrink wrap on all connectors
3. use the OEM horn wire to the stebel horn relay. The horn on wire is not in the alarm socket
4. Dielectric grease all connections
Stebel Airhorn, comes with relay. Don't get the airhorns from Italy. Their connections are different and can not be modified
out of package
need to pry airhorn from exit nozzle here
slides off like this
need to measure nozzle inlet hole diameter
use Ball gage
measure with calipers right at .353 inches
measure air horn outflow nozzle, at .340 inch
fit the air horn right in this cavity....Make a electrical panel to attach the horn and relay. See the how-to for instructions:
Vespa GTS electrical accessory panel install step-by-step
attach airhorn to electrical accessory panel mount
attach relay...2x shown one for airhorn, one for heated jacket/gloves (another pitch)
measure distance from airhorn to panel
cut rubber stopper to size
mechanically attach stopper to electrical accessory panel
airhorn rest on stopper for support
don't need the nozzle attach brackets, best to remove them
cut with band saw
remaining part
this is the connection hose needed, 5/16 inner diameter, get the vacuum hose, not the fuel hose 2 foot is plenty long
need some hose clamps, I'll use these for now and replace them with quick connects
get abunch of these elbow connectors at 5/16 in 5/16 out. since these are Tee's need to cap off one end, just melt it shut or epoxy closed
mix equal part resin and accelerator
glue end with epoxy and jam into nozzle inlet hole, let cure. position elbow connector like so
attach 5/16 hose to air horn as shown to direct compressed air toward OEM horn location when mounted
should look like this
attach electrical attach panel into left knee cavity
nozzle fits on the interior of the horn cavity
remove OEM horn, disconnect wiring
horn removed
the orientation that fits and allows drainage. There are only 2 angles that fit. This is not the best, but allows drainage if water ingresses into the horn. allows outer cover to be removed. Zip tie into position.
running hose from nozzle back to horn compressor for attachment.
compressor in knee cavity
zip tied nozzle
Results:
I enjoy the piece of mind the loud horn provides. I believe a must for all 2 wheel riders.
Enjoy and all the best!
Keithm
Couple extra shots as an FYI....
dielectric grease
wire crimper tool, don't use plyers
10 gage wire spool
properly made female spade connected to 10 gage wire
relay instructions
close-up of my wire connections
using a heat gun to shrink spade connector
