@keithm avatar
GTS 250
@keithm avatar
GTS 250
Enclosed is a step-by-step walk thru outlining fabricating a mounting for the iphone5 on a Vespa 250ie GTS. The process would be similar and compatible to other vespa models also. The intent of the mod is to allow usage of the GPS feature (google maps) while touring. I have also added a few views of the waterproof USB port added. The USB port provides continuous power to the phone while the bike is on. I have used an identical mount for many miles on my now sold KLR650.
start by fabricating the mounting bracket. I used 6061-T6 aluminum sheet at t = .063 inch.
trace the relative rough size needed to accept the iphone
band saw cut
use fillet radii to blend the corners of the mount, to match contour of phone for the polished look
trace outline on mounting backplate bracket
trim at disc sander
like so
need to break edges with the deburring tool
quick fit check....A-ok
now to mount the phone to the bracket, use 2x strips of super heavy duty loop style velcro. This will stay attached to the phone permanently. I use this to also mount the phone in my car while using the GPS feature, listening to Adam Corolla POD casts, or Pandora internet radio.
add matching hook velcro to the mounting pad. the velcro is self adhesive and can be found at home depot
now to mechanically mount the phone pad to the handle bar faring, on left side by mirror bracket, this part requires drilling 2x small holes
use small metric size 4, 100 degree countersunk stainless steel fasteners with adequate grip length
locate fastener in bin
drill and attach here, use blue locktite on threads for secure attachment of bolt to nut
although not shown , I did add loop (soft sided) velcro to the mounting plate to protect the finish of the front faring, kinda see it in this view with phone mounted
mounting plate view
phone attached
waterproof USB outlet mounted on left knee pad. Will show this in more detail in future thread
view showing the quick disconnect plug and play chords for heated jacket, heated gloves and USB socket...
I need a iphone chord 18 inches long. If too long will flop in the wind, if too short will not allow full travel of handlebar stearing. I will use an iphone chord (6 inches) + usb extension (12 inches)
when connected
white electrical tape to splice the usb extension to iphone chord
pull taught and wrap joint with tape
need to check with phone
hard left, no interference with steering or knees
map stays in landscape plane while riding
Observations:
1. Like the ability to attach/detach phone quickly.
2. Although it may seem risky, I have driven many miles with similar configuration with the KLR without issue. The phone stays attached.
3. I don't use the power chord much as the iphone 5 battery life is usually not an issue
4. Maybe thinking of some bluetooth inside the helmet so I can hear the GPS guidance direction.
5. One issue is once the GPS is set, I can not screen scroll with gloves on. maybe that is best anyways.....
Enjoy and all the best!
Keithm
@gogogordy avatar
Reprehensible Misinformant
@gogogordy avatar
Mad skills!
Did you ever work for an airplane manufacturer
@keithm avatar
GTS 250
@keithm avatar
GTS 250
Re: Mad skills!
Why yes I do work, as an structural engineer, at a large aerospace manufacture. My part time hobbies include wrenching and tinkering.
Keithm
@gts300ss avatar
GTS300SS
@gts300ss avatar
GTS300SS
sorry bit to me it look like a bit kermis tuning.... Also the voltmeter
But only my oponion...
@keithm avatar
GTS 250
@keithm avatar
GTS 250
Thanks...I think?
Keithm
@keithm avatar
GTS 250
@keithm avatar
GTS 250
I recently picked up a perhaps better chord to connect the USB outlet socket to the iphone5. The chord is retractable providing the correct length. Don't want the chord too long as it will flop in the air at speed.
The chord, direct from China!
as installed in the USB socket
extends ~3 feet, only needs 18 inches (1.5 ft)
As installed with Google maps app turned on
no clearance issues...
Observations of chord...
1. better option than straight chord + USB extension
2. More compact for storage
Enjoy,
keithm
I just use one of these and it works flawlessly.
http://www.youtube.com/watch?feature=player_embedded&v=Irh8stSyWAs
[ Time: 0.0091s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
