Wed, 09 May 2007 03:36:12 +0000
None. Maybe again someday when Michelle won't worry.
Wed, 09 May 2007 03:36:12 +0000 quote
Bought it from Scooterwest.com. The instructions were easy to follow with color pictures to show the way. Took about one hour start to finish. Love the final result. Should have done it sooner. Highly recommend this mod for all you LX and Fly owners. Not sure it works on the Fly but I bet they could tell you at Scooterwest.
Just wanted to pass that along,
Doug
Wed, 09 May 2007 05:10:44 +0000
Stella
Stella
Wed, 09 May 2007 05:10:44 +0000 quote
Thanks Doug! I got my conversion kit last week and plan on installing it soon!
Thu, 10 May 2007 00:04:01 +0000
Thu, 10 May 2007 00:04:01 +0000 quote
I love mine, it looks great!!
Mel
Tue, 15 May 2007 00:26:06 +0000
2007 Vespa GTS 250
2007 Vespa GTS 250
Tue, 15 May 2007 00:26:06 +0000 quote
When you install these Euro LX Turn Signals, do you still have the white running lights and how does that work. The site says it goes from a 10 watt to a 5 watt bulb. If its a dual filament bulb, then are the running lights yellow color instead of the white? Also, you say it comes with instructions. How easy is it to install and how much taking apart of the bike do I have to do (is it just some simple screws)? And, last, if I wanted to sell the bike, for whatever reason, could the original ones be put back without messing anything up? Thanks...looks great but I do like the white running lights~
Tue, 15 May 2007 00:43:16 +0000
Tue, 15 May 2007 00:43:16 +0000 quote
The running lights are yellow, and it's a dual-filament bulb. All you have to take off is the horn cover, and the top of the headset. And it all just plugs in to existing connections -- should be very easy to return to original condition if you sell it.
-Dan
Tue, 15 May 2007 02:15:49 +0000
Aprilia Sportcity Cube 250ie, Stella 2T
Tue, 15 May 2007 02:15:49 +0000 quote
As it says below....
Wed, 16 May 2007 00:51:03 +0000
'06 Vespa LX150, '07 Suzuki Burgman 400, '05 Honda Metropolitan
Wed, 16 May 2007 00:51:03 +0000 quote
Wed, 16 May 2007 19:34:03 +0000
Wed, 16 May 2007 19:34:03 +0000 quote
Smorris wrote:
I really like that center light. I may have to do that mod, too! Bet it would look great on my Black LX!
-Dan
⬆️    About 5w elapsed between posts    ⬇️
Sat, 23 Jun 2007 21:22:28 +0000
Sat, 23 Jun 2007 21:22:28 +0000 quote
dchernikoff wrote:
-Dan
Hi there,
where can I order such a headlight?
It would look nice on my midnight blue LX!
Sun, 24 Jun 2007 00:36:37 +0000
Sun, 24 Jun 2007 00:36:37 +0000 quote
Sieds wrote:
dchernikoff wrote:
-Dan
Hi there,
It's for a GTS, and you'll have to cut a large hold into the LX cover for it to fit. Someone did a project report on it here, I think.
-Dan
Sun, 24 Jun 2007 00:53:05 +0000
Sun, 24 Jun 2007 00:53:05 +0000 quote
Sieds wrote:
Hi there,
Hi Sieds,
It is not made for the LX, but is an accessory for the GT. IT is available from Motorsports Scooters (see banner) under the GT chrome accessories.
It is NOT a plug and play piece to add to an LX. You will have to cut away not only the vents in the horn cover, but part of the surrounding material as well. The profile of the LX cover is more pointed than the GT, too, so you'll need to deform the cover while gluing it in place.
Here are my photos from when I did it.
http://www.modernvespa.com/forum/viewtopic.php?t=8743
Sun, 24 Jun 2007 01:05:09 +0000
Sun, 24 Jun 2007 01:05:09 +0000 quote
That's hot.
  DoubleGood Design
[ Time: 0.0440s ][ Queries: 6 (0.0206s) ][ Debug on ][ 286 ][ Thing Two ]
