2007 Vespa GTS 250 Yellow
Hello there,
My vespa has been sitting in the garage for most of the winter, and I have taken it out a couple of times. What I see now is that when the engine speed is slow, it will stop. Like, if I start the engine and not speed up, it will immediately die. If I stop at red light, it will stop as well. My workaround now is that when I stop at red light, I will turn on both throttle and break so it won't die. I don't have much trouble starting it though, especially if I turn the engine throttle. What could be going wrong?
@techenigma avatar
2007 Vespa GT200 - 2010 Vespa GTS 300 Super - 2013 Piaggio BV 350
@techenigma avatar
gummed up fuel injector? I immediately thought idle jet, but you have a GTS 250 which is fuel injected. Did you winterize the bike prior to the winter storage? Try some seafoam in the tank and run the bike a good distance to let it work through. I had a dirty idle jet and that worked for me...
@raiderfn31 avatar
PGO Buddy 150 "St Tropez" imported by Genuine scooter co.
@raiderfn31 avatar
You may need to drain the gas. Did you put a stabilizer in the gas before storage?
ooops, I didn't put in anything in the gas for storage, and it was a full tank of gas. Is seafoam the solution?
@raiderfn31 avatar
@raiderfn31 avatar
IMHO it is worth a shot. You will have to keep it running so the Seafoam can get through the whole system.
@dooglas avatar
@dooglas avatar
And, if Seafoam doesn't do it - I'd say the next step is throttle body cleaner in a spray can.
[ Time: 0.0119s ][ Queries: 3 (0.0048s) ][ live ][ 313 ][ ThingOne ]
