Also I read here that the Super's seat is firmer, but someone working at my dealer said they were the same except cosmetically.
Lastly the bore and stroke is (are?) different. How does that translate?
Customized 2006 LX150 Thunderbolt the Wondercolt
Posts: 937 Location: Santa Monica, CA |
Lastly the bore and stroke is (are?) different. How does that translate? |
It could be better. You're restricted a bit with removing the hump as the plastic moulded underside dictates the profile somewhat.
Bore and stroke |
Re: Do people here think the GTS 300 seat is comfortable?
Vespizzare wrote: Also I read here that the Super's seat is firmer, but someone working at my dealer said they were the same except cosmetically. Lastly the bore and stroke is (are?) different. How does that translate? Bore is the diameter of the cylinder. Stroke is the distance the piston travels within the cylinder. Is that what you were asking? |
No. I find the GTS300 seat to be the least comfortable of the GT/GTS line.
The GT200 seat (which will fit nicely on a GTS frame) is, IMHO, the most comfortable. |
saggezza di scala
Posts: 7068 Location: Israel |
saggezza di scala
jess wrote: No. I find the GTS300 seat to be the least comfortable of the GT/GTS line. The GT200 seat (which will fit nicely on a GTS frame) is, IMHO, the most comfortable. Is the plastic part of the GTS seat the same as the GT200? I ask because I had a local seat guy shave down the foam on my GTS seat and add a little padding to even it out even more... but I can still feel the hump under there. |
NightWing wrote: Vespizzare wrote: Also I read here that the Super's seat is firmer, but someone working at my dealer said they were the same except cosmetically. Lastly the bore and stroke is (are?) different. How does that translate? Bore is the diameter of the cylinder. Stroke is the distance the piston travels within the cylinder. Is that what you were asking? 2) How does the different bore and stroke figures of the two GTS models affect performance? |
Treppenwitz wrote: Is the plastic part of the GTS seat the same as the GT200? I ask because I had a local seat guy shave down the foam on my GTS seat and add a little padding to even it out even more... but I can still feel the hump under there. The padding, though, is different. It's sculpted differently, and I think the density is different. So while the hump is there in the seat pan of the GT200, the foam around it doesn't reinforce the hump so much. In the CB2012 prep thread, I showed my seat pan modification where I de-humped the GT200 seat. Let me see if I can find that. |
Here you go: start reading at this post, and work down:
https://modernvespa.com/forum/post1337089#1337089 |
saggezza di scala
saggezza di scala
jess wrote: Here you go: start reading at this post, and work down: https://modernvespa.com/forum/post1337089#1337089 We're talking about the extra seat I have thanks to my donor scooter, so no hurry. |
GTS 300ABS, Buddy Kick 125
Posts: 13559 Location: Oregon City, OR |
Vespizzare wrote: NightWing wrote: Vespizzare wrote: Also I read here that the Super's seat is firmer, but someone working at my dealer said they were the same except cosmetically. Lastly the bore and stroke is (are?) different. How does that translate? Bore is the diameter of the cylinder. Stroke is the distance the piston travels within the cylinder. Is that what you were asking? 2) How does the different bore and stroke figures of the two GTS models affect performance? |
lone_airedale wrote: I much prefer the GTS seat to the GT. YMMV. |
Wanted
Posts: 5486 Location: Jacksonville, Florida. Weaverville, NC |
jess wrote: No. I find the GTS300 seat to be the least comfortable of the GT/GTS line. The GT200 seat (which will fit nicely on a GTS frame) is, IMHO, the most comfortable. The black 2006 seat is considerably softer than the white 2005 seat, and I am beginning to prefer the harder one. More support for the long rides. But both are fine. So much better than the split level seats with little seat backs on the BV or other maxi bikes. I cant stand those. |
Vespizzare wrote: lone_airedale wrote: I much prefer the GTS seat to the GT. YMMV. |
RIP
Before you do...
I had Pirate do a de-bump of my GTS seat, so I could sit further back: it was good for a couple of months, then his favored gel insert broke up and it became worse than ever.
Treppenwitz wrote: Thanks. I may see if my seat guy is willing to try that. Barring that, I suppose I could always send it to Pirate (with a link to your thread) and pick it up when I am in the US in August. |
judy wrote: VESP our not getting rid of the LX are you? 1) with more longer distances (over sometimes bumpy pavement and "possibly" on the freeway). 2) more riding double 3) truth told, I was sorry I didn't get red, so I can re-do that one too |
Posts: 763 Location: Northern Virginia |
I had Pirate shave the seat down 3 inches in front (I'm inseam challenged). Got the seat in April, so far no problems and I actually can put the balls of my feet on the pavement at a stop. The seat is much flatter than the stock seat, and it's comfortable enough. At age 62, nothing feels quite right anymore so I've given up trying to find seat perfection.
Vespa 300ie Super, Honda PCX150
Posts: 172 Location: north of Lewiston, Maine |
Only been riding two months, so not sure how much my opinion is worth, but I find the GTS 300 seat hump to be just a little bit too close to the front of the bike for perfect comfort (I am just under 6' tall). So sometimes I sit in front of it, and then when my legs get cramped, I sit ON it. But after a few miles that gets old, too. I tried sitting behind it for about 2 seconds, but found that I could not confidently steer with my arms stretched that far..... I have not attempted to ride with a passenger yet, perhaps when I do so I will find the hump to be perfectly suited for that.
2013 VespaGts300 Super Sport SE Vader part Deux, 2009 Vespa Lx150, 1976 Vespa Rally 200
Posts: 419 Location: Albany, NY |
I believe I have the same seat on my GTS 250 and I hate it. Needs more padding. Definitely thinking of sending my seat out to these guys to be
re upholstered and gel added. http://www.pirateupholstery.com/photos/scooterseats/#GT |
P.S. I''m 5'9" and 150lbs. I consider the bump a non-issue. For it to bother me, I'd have be sitting back too far (and hurting my back in the process).
there is no "right" answer to the seat question as everyone is a little different.
I'm 6'2" and generally want to sit futher back than most, typically exactly where most manufactures put the "hump" that seporates the rider from the passenger sections. I also just switched from the flat GT200 seat to the stepped GTS seat (to change the rack, not because of the seat actually). Given that, you would think I would not like the GTS seat as well. As it turns out, it doesn't really matter that much to me. Now whether that's because of the foam, the hump, or just my ass going numb from sitting on seats for years designed to fit someone else I can't say. It does suggest, however, that the only way to know for sure is for you is to sit on one because in the end, that's the only fit that matters. |
When I had my 300 Super, I found the seat to be completely unbearable after 100 miles or so. I looked into having the seat redone, but the price scarred me off. I opted for the Airhawk seat cushion and have never looked back. May not add much on the looks end, but it completely changed my riding experience. Worth the money if you are looking for a relatively cheap improvement to your comfort. Also, it can be removed in about 10 seconds if you don't like the way it looks.
I've just done 450 miles in a day on my 300 Super Sport. The seat becomes uncomfortable at around 80 miles on it. The GT seat is definitely the most comfortable.
2012 Vespa GTS 300 Super, 08 Vespa LX150, 2000 BMW R1100RT, 01 Honda Reflex (sold)
Posts: 177 Location: Western North Carolina |
Wick,
Do you recall what size/model Airhawk you bought. The bum goes numb after just a few (50) miles while riding my GTS 300. |
saggezza di scala
saggezza di scala
'04 Stella 2T GB150 '15 Genuine Roughhouse 50 '17 Kawasaki Versys 650
Posts: 355 Location: Philadelphia |
Why is that hump there? I have never felt comfortable on a scoot with a hump. Many scooters that I have been interested in have been eliminated because of that hump.
IMO the seats on earlier scooters were way more comfortable than the current models. |
RoaringTodd wrote: Why is that hump there? I have never felt comfortable on a scoot with a hump. the driver, there by avoiding the dreaded "I'm looking at the back of your head all the time" syndrome as well as helment slap at stops. That can work if you happen to be the exact size it was designed for (or smaller). If you are larger tho, the hump tends get in the way in general and limits your ability to move around. On 100HP sport bikes, it can also keep you from sliding off tho on 22HP scooters that tends to be less of a problem. |
railchaser wrote: Wick, Do you recall what size/model Airhawk you bought. The bum goes numb after just a few (50) miles while riding my GTS 300. |
Another note. There are two different types of Airhawk. The original Airhawk and the Airhawk 2. The difference is the bladder. The original has a thicker bladder and has a longer warranty. Look around online for the best price. Brick and mortar stores can charge as much as $200 for the original. I bought mine for less than $125 shipped. Also, look up Airhawk on youtube. That is what finally sold me on it.
Posts: 4755 Location: Hertford, North Carolina |
I had a local upholsterer shave off the hump on the GTS 250 for around $80. He was able to keep the original material. Then when I traded it in for a 300 Scoot Richmond swapped the seat. That eliminated the piping as well.
GT. I found no need to adjust it. They sell for $60-150. I've bought and sold a half dozen and finally got my favored color. I liked them so much I had two in my stash. I sold the one I paid the most for to get most of my expense on it back. Then I sold my last backup to someone here. I'm thinking that was dumb. They're getting as common as hens teeth. Although one recently went for $100 on MV. A steal in the current market IMO.
The Beer Guy
2010 GTS 300 Super and 2015 Kawasaki Versys 650 LT
Posts: 4744 Location: Nelson County, VA |
tomjasz wrote: GT. I found no need to adjust it. They sell for $60-150. I've bought and sold a half dozen and finally got my favored color. I liked them so much I had two in my stash. I sold the one I paid the most for to get most of my expense on it back. Then I sold my last backup to someone here. I'm thinking that was dumb. They're getting as common as hens teeth. Although one recently went for $100 on MV. A steal in the current market IMO. |
rider33 wrote: RoaringTodd wrote: Why is that hump there? I have never felt comfortable on a scoot with a hump. the driver, there by avoiding the dreaded "I'm looking at the back of your head all the time" syndrome as well as helment slap at stops. |
jess wrote: That, and the specific spot in the seat where the hump is the most pronounced also allows clearance for helmets in the underseat bucket. I think her helmet could almost fit inside mine was well..... |
Posts: 1757 Location: Hatfield, Pennsylvania |
I think the GTS Super seat is comfortable as far as padding goes, but since I'm 6'4" with a 36" inseam, I cannot sit back far enough for knee comfort with the hump.
I traded another MV member my Super seat for their GT200 seat and rack and have been very happy. I've also acquired a matching backrest from another member that I'll install when I get some free time.
GT200 seat and rack. Have since removed the seat strap
