Hi all
First post here but I've used the knowledge in here a lot.
I'm in the process of changing carb from o Weber to a dellorto 17.5mm due to well known starting issues. It started on the first kick but the idle was waaaay high and the scooter took off... First I thought it was the idle screw but after a while investigating I now think it's just the throttle cable that is too short.
Now the question:
I've read somewhere that there is more than one cable going from the handle or at least connected to the same. Can I adjust the cable in some way without affecting other things like the oil pump or whatever is connected on the same cable?
Thanks!
