@gregm avatar
2003 ET4 150
@gregm avatar
2003 ET4 150
We replaced the battery but LX50 wouldn't start. Next day, it would start, run for a few minutes, then die. Giving it more fuel would also kill it. Did this several times.
We drained the gas tank thinking it's bad gas (daughter hadn't ridden it for a year).
Not sure what to try next--put in fresh gas, check a filter, other?
Any help is appreciated.
Greg
07 LX50
07 LX50
Most likely clogged jets.
@gregm avatar
2003 ET4 150
@gregm avatar
2003 ET4 150
Any guidance on how to clean them?
Greg
07 LX50
07 LX50
07 LX50
07 LX50
I unplug the choke and remove the carb with front manifold and air box hose on .Pull vac line and fuel line off ,bottom drain hose.and put it on the bench.
@gregm avatar
2003 ET4 150
@gregm avatar
2003 ET4 150
Thanks!
[ Time: 0.0123s ][ Queries: 4 (0.0044s) ][ live ][ 334 ][ ThingOne ]
