to the guru's out there
after mounting an e ignition kit from sip (seriepro premium) ive found it is down on power when it is stood still it will not "rev out" like it did before ive checked and double checked the timing set @ 26deg tried advancing / retarding still with no difference cleaned out the carb adjusted the mixture screw no difference (it sounds exactly like a leaf blower )
the carb is the original with the choke as a flap in the airfilter
the crank that came with the kit was a mazzuchelli that has the fly side cone for a px type flywheel and stator i'm not sure if the induction timings are any different
i have noticed that when the engine is running it doesn't "throw" any where near as much fuel out of the carb as it did before
hope some one can help
