@keithm avatar
GTS 250
@keithm avatar
GTS 250
Enclosed is a side-by-side comparison between the Vespa GTS exhaust gasket and the Yamaha Equivalent exhaust gasket. The advantages of the Yamaha gasket is it's price is quite abit less than the Vespa's gasket ($12 vs $20).
Gaskets
left = Vespa gasket from scooter west at $19.99 (part # 826388)
Right = Yamaha Gasket from Amazon at $12.96 (part # 3YF-14714-00)
outer diameter measured
Vespa = 1.518 inch
Yamaha = 1.485 inch
Yamaha is ~2% smaller
gasket wall thickness measured
Vespa = .126 inch
Yamaha = 1.193 inch
Yamaha is ~2% thinner
weight equivalent at 20 grams each
summary chart of measurements
Enjoy! Given the differences, I'll likely stick with OEM and keep the Yamaha gasket if I'm in a pinch.
Keithm
@hachi avatar
2005 GT 200
@hachi avatar
2005 GT 200
I had researched that before and found that there was very little difference. I installed the Yamaha part with no ill effects that I know of. I also have a spare to carry with me. Thanks for the research keithm!
@zombies-nyc avatar
@zombies-nyc avatar
Some one stole all the cookies off your tray. Razz emoticon
@wick avatar
2009 Piaggio MP3 500
@wick avatar
Hilarious! ROFL emoticon
@keithm avatar
GTS 250
@keithm avatar
GTS 250
Why you......
The GTS's custom over-sized functional rear rack
guess It does kinda sorta look like a cookie tray...hehehe
Keithm
@masala avatar
@masala avatar
946
I love, love, love parts cross-reference threads... SO useful when, a few years down the road, some Vespa owner in Nowheresville is searching teh Interwebs for an exhaust gasket solution because they have no local dealer, and they'll (hopefully) find this thread. Props!
That's the old style Vespa gasket as well, the new ones are much much better, a stainless mesh coated in graphite.
@zagato avatar
Vespa GTV 250ie
@zagato avatar
Vespa GTV 250ie
Did the Yamaha gasket fit with no modification? I tried using one and had to remove a considerable amount of material from the inside diameter of the Yamaha gasket making it even thinner. I ended up going back to the OEM which fit like a glove.
To me, the are similar, but not equivalent.
@keithm avatar
GTS 250
@keithm avatar
GTS 250
Not sure why, but scooterwest does not seem to carry the New style (with the stainless steel mesh on end). I would have liked to include the new style within the comparison study.
Keithm
@keithm avatar
GTS 250
@keithm avatar
GTS 250
keithm wrote:
Why you......
Guess It does kinda sorta look like a cookie tray...hehehe
Keithm
@hachi avatar
2005 GT 200
@hachi avatar
2005 GT 200
To me, they are similar, but not equivalent.
Did you sand the end of the downpipe? I sanded and steel wooled the end of the downpipe and it slid right on with no problem. Mine is a GT200 though and I don't know if it is different than your GTV250.
@ckaiserca avatar
@ckaiserca avatar
Excellent post! Thanks for the information.
[ Time: 0.0203s ][ Queries: 3 (0.0141s) ][ live ][ 318 ][ ThingOne ]
