ok just to get this straight
items required prior to oil change and hub oil change.
1 oil
2 oil filter
3 drain plug o-ring
4 filter o-ring
5 oil strainer o-ring
6 sealing washer(gearbox)
7 split pin (wheel)
8 exaust port gasket
9 gearbox oil.
order
1 remove side panel
2 remove access port
3 remove/disconect oxygen sensor
4 remove exaust
5 remove wheel
do oil and filter change
do gearbox oil change
put every thing back in reverse
have I missed anything?
cheers
Bjorn
