I'm new to this forum. I recently purchased a 2001 ET2 50cc w 96 miles on it. It appears to be completely stock. Drained the fuel, replaced the fuel tap and the fuel and vacuum hoses. Took the carburator apart and cleaned it. Put it back together and by putting fuel in the spark plug hole 3 or 4 times was able to get it to start and idle just fine. I'm running 50-1 non ethanol fuel mix in it until I can be sure the oil pump is working properly. When I give it throttle it revs and then it bogs down. I'm guessing it bogs down due to either too much or not enough fuel. The spark plug is new.
1. Im trying to run the scooter without the air box connected as the foam air filter had deteriorated and I am waiting on a new one. Could this be affecting the fuel/air mixure. Does the air flow need to be restricted by the foam filter?
2. The carburetor is a small Weber carburetor. You can read "Weber" on top of the throttle assembly if this helps identify it. When I took it apart the only rubber parts I found were on the tip of the float needle and the float bowl gasket. Neither of the 2 other needles had rubber o rings or washers. Should there have been o rings in any other places? Is it possible that the deteriorated over time? Could this be my problem?
