@waterboysh avatar
2013 BV 350
@waterboysh avatar
2013 BV 350
This may seem like a silly question, but it's something I'm a little concerned about after reading the thread about the BV 350 not idling well. Lots of people were talking about overfilling it and some kind of roll over valve. I don't actually have a BV 350 yet, but I plan on getting one soon and since there is apparently a wrong way to fill it up, I want to know what the right way is. I've seen a few people mention "burping it" but I don't really know what that means.
On my current scooter, the gas tank is under the seat and there is a flat metal bar near the top of the tank that prevents me from inserting the gas nozzle further than about 1 or 2 inches, so I just hold the nozzle near the tip of the tank and watch for the gas level to come about level with that flat metal bar. I took a quick look at the BV 350 gas tank and it seems completely different. Will the metal gas nozzle fit right in and just cut off at the right moment?
What exactly happens if you overfill it anyway? What's the worse thing that could happen?
BV350 "Black Vidow"
BV350 "Black Vidow"
I live in California and all the pumps have stupid 'foreskin'....
I have yet to figure out how to fill up without overflow. Quite a pain. Fast, slow, angled forward, angled backward. No good. I'm going to get a small gas can and fill up at home every 120 miles. When on long road trips, I'll try my damndest to not overfill and then just cleanup the inevitable mess.
That said - if you fear the rough idle due to overflow issue - remove EPA crap ... easy procedure and I'd be happy to send you detailed instructions. Please note - removal of EPA crap has no effect on performance, handling, mpg, or other. I just did it for more space in the pet carrier and because of the possibility of the idle issue.
@drweside avatar
BV 350
@drweside avatar
BV 350
Are you guys talking about overflow or splashback? I've yet to encounter an overflow problem, but a little splashback does happen when I use one of pumps without foreskin. When the pump hits the first stop, I start to pump slowly and visually check the fuel level in the neck. When I can see that I'm near the top, I stop pumping.
Edit: I can get the nozzle into the tank quite far down. That's probably why I get so little splashback when it does happen.
@hank_hill avatar
Lawn Tractor
@hank_hill avatar
Lawn Tractor
Peel it back. Razz emoticon When filling up small tanks like scooters have, have both hands on the handle, and look down into the tank as it fills. You have to get good at "feathering" the trigger. Putting the nozzle in a clicking the trigger then walking away..... bad things man, very bad things.
Good luck with that foreskin.
@drweside avatar
BV 350
@drweside avatar
BV 350
I miss King of the Hill...
@hank_hill avatar
Lawn Tractor
@hank_hill avatar
Lawn Tractor
BWAAHHHH!
@syd avatar
@syd avatar
I started the (or one of the) BV350 idling problem threads. I now think my idling problem was a fluke, possibly engine heat related - first service showed low coolant level.
I have overflowed the tank when fueling several times. I find it difficult not to overflow. But I have never experienced problems after overflowing the tank, of any kind. I too would like to find a repeatable way to fill the tank without overflowing. Cleaning up every time is a pain.
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
I seriously doubt anyone is having a rough idling problem due to over filling the tank on a BV350. The gas tank is quite low on a 350 unlike the Vespas. If you do overfill it, the gas simply runs over into the catch area around the filler neck and drains out through a tube onto the ground. The evap system is higher than the tank and it seems unlikely to me that overfilling could force fuel up into the evap cannister. My experience with the evap system on the BV350 is that it is trouble-free and not a source of problems. As far as filling the 350 - I pick stations without the large hood around the nozzle. I fuel with the nozzle oriented from the side, insert it all the way into the tank, and continue until the auto shutoff. I do not top up. I'm not having difficulty with overfilling.
@syd avatar
@syd avatar
Dooglas wrote:
I do not top up.
Ooh, ok, I'll try.
@bvee avatar
BV 350
@bvee avatar
BV 350
Ditto with that
@grscum avatar
2012 BMW G650GS, 2006 GTS,
@grscum avatar
Yardsale endorsed: http://www.mccuff.com/
@fencing_fan avatar
2018 GTS 300. Montebianco
@fencing_fan avatar
Filling the BV seems to require its own secret handshake, much like the GTS. I haven't had my BV long enough to have had to put fuel in it more than twice, but I have't had a nozzle shut off problem or an overflow happen. I did notice that if I insert the nozzle in all the way, stop a the first auto-off point, that there is room in the tank for another litre or so.
Not sure if that would the be litre too much, but it might be worth keeping in mind if others, like me, tend to use a trip odo to determine when it's time to refuel.
@scootergirlinal avatar
2012 BV 350
2012 BV 350
Fencing Fan wrote:
...I did notice that if I insert the nozzle in all the way, stop a the first auto-off point, that there is room in the tank for another litre or so.
I've found the same thing with the auto-off point. I remove the nozzle, shake the handle bars, and the tank seems to "burp" allowing more room for fuel.
@dooglas avatar
@dooglas avatar
And the ones who are trying to get that last half liter of fuel in are the ones who are overflowing the tank .
@scooter10s avatar
2001 ET4 150 Red, 2010 GTS 300 Volcano Black, 2013 BV 350 Silver/Black
@scooter10s avatar
Therein may lie the problem...the extra filling past shutoff may enable the idling problem to occur. I had the problem once and the dealer claimed they needed to drain and dry the evap system to fix the idling problem. Until more folks post their experience I will not try to add any more fuel after the auto shutoff. I think there is enough fuel capacity and enough fuel economy with the BV 350 to avoid the risk.
@bvbob avatar
@bvbob avatar
It WILL run up the line into the evap canister. My bv200 has (had) the same set up. I removed the roll-over valve etc. but kept the line running over the air filter assembly. Too lazy to run it straight down to the ground. I'll get to it someday.... It still to this day sometimes shoots gas out of that hose. I just filled it up an hour ago. STOP at the first auto shutoff. RESIST the urge to top it up. Chant that as you're filling it. My garage smelled of gas the last time I over filled it for a week. I filled (over filled) it and rode it straight home then it rained for a week solid. It shot gas out of that hose Couldn't wait to get it out on the road to burn off some fuel.
Bob
2012 BV 350
2012 BV 350
Not so far; if the fuel doesn't go down when I jostle the scooter, I don't continue to fill the tank.
@fencing_fan avatar
@fencing_fan avatar
fuelling and BV 350 range
If I can skew this topic a bit, I'd like to know what sort of distance others are able to go on a full tank on the BV350. I just did about 210 kms, and still only put about 8.5 l in; that leaves almost 5 l in the tank, assuming a 13 - 14l total fuel capacity. My fuel light had come on about 10 k earlier.
For you imperial holdouts, I did 130 miles, but still had a gallon or more (US gal) in the tank, at least as far as total tank capacity goes.
So, just wondering what others are getting for tank range, in general commuting use.
@syd avatar
@syd avatar
Re: fuelling and BV 350 range
Wow, I must be hard on the throttle, My low-fuel light has been coming on in the 110 - 120mile range. I haven't ridden very far after the light came on, but only average 2 gallons, give or take.
Some day I'll get used to the feeling of the throttle response, but not yet.
@kruella_dv avatar
Piaggio Beverly Sport Tourer (BV350)
@kruella_dv avatar
I'm afraid we use mixed units in England . I regularly travel between 135 and 140 miles before the low-fuel warning light comes on. I then usually refill within 10-15 miles and put anywhere between 8 and 8.5 litres of fuel to completetly refill. I'm keeping track of fuel consumption (on an Excel Spreadsheet, not fuelly) and am averaging 73mpg (imperial gallon). The current short-term average over a few fill-ups is over 75mpg (warmer weather? - yes. Slower riding? - just a little easing on acceleration )
Regards, John W/
@tn_sooner avatar
@tn_sooner avatar
I believe Hernesage has posted the best information (ran the tank dry twice) at the thread linked below, but here is the post:
hernesage wrote:
FWIW. A couple of scenarios from a long trip this week end.
Setup:
- Starting with a full tank and reset the odo each time.
- Removed the stock windscreen and have a Shad 48 topcase.
- Speed measured by GPS.
- The bike is just starting out, currently with 650 miles.
1. City:
Avg speed: 45 - 50 MPH (once topped at 60 for a minute)
Light on: 142 miles (0.87 gallons calculated)
Bingo: 199.8 miles
Fill: 2.982 gallons
MPG: 66.6
2. Highway
Avg speed: 83 mph (this was WOT cuz I had to get home)
Light on: 120 miles (0.75 gallons calculated)
Bingo: 160.2 miles
Fill: 2.994 gallons
MPG: 53.5
In both cases I filled up from dry. Yup, walk of shame up to the pump. <Next>
This stunt put me over the break-in mileage (and gave my calves a serious workout) so I will be taking it into the shop for maintenance (and a rest). Given other peoples experience I expect to gain some mpg around 1500 miles. I don't know where that remaining 0.4 gallons total capacity went but I sure could have used it.
https://modernvespa.com/forum/posting.php?mode=quote&p=1628102
@fencing_fan avatar
@fencing_fan avatar
TN_Sooner
Yep, you're correct. I missed this one, but continued a related thread rather than starting a new one.
Still, thanks to others who chimed in anyway.
@waterboysh avatar
2013 BV 350
@waterboysh avatar
2013 BV 350
So, I filled up my BV 350 for the first time a couple of days ago. I just put the nozzle in and let it go until it auto cut off. This only filled the tank up to about 3/4. I had gone about 140 miles when the low fuel light came on and put right at 2 gallons in it. It probably would have held another 1/2 gallon though.
Any tips for getting it to full without overfilling? Should I just not stick the nozzle down all the way, but only put it down a few inches?
Vespa GTS 300 2020 Yacht Club
It is really annoying filling up my 350. Always splashing out every time I fill up.
2015 MP3 500
2015 MP3 500
Long trips calculated
I have had my BV350 since day 1 in the USA and I love it. I have taken it on a 3500 mile round trip and thanks to a gas can made for cycling I was able to run the tank dry to calculate fuel storage and use.
This is the can I used http://www.redagascan.com.
I was able to run at a variable throttle of 50mph to 85mph (which is average for a tank for me on open road) and went 164 miles before the engine shut off. Here is the problem though, Piaggio says the tank is 3.4 US Gal but I have never been able to get more than 2.9ish even when "topping off".
As for the overflowing I found the same thing about putting the handle all the way down and stopping at the first shut off. During normal use I am never so far from a fueling station that I need to squeeze as much as I can in there. On really long rides where every drop of fuel counts (some places are more than 200 mile to a fuel station) I get everything I can in that tank and have the back up can with me...but I risk the overflow at that point.
TC
[ Time: 0.0132s ][ Queries: 3 (0.0054s) ][ live ][ 341 ][ ThingOne ]
