85 basket case... Working out
After hooking up the wiring... the following works: high and low light, kill switch, key switch, brakes switches and rear brake light.
I have not tried the starter (used electrical tape on the ends)... The natural indicator not connected (used electrical tape on the ends) and fuel tank sensor not connected.
I have low but good battery...
Now for the advice part... I am getting a max of 3.5 volts to the horn but it makes noise. The blinkers are not working. I am getting about 3V volts into the blinker relay via a regulator. Before checking voltage I replaced the blinker relay from auto part store.
Bad regulator?
