Got the idle problem fixed I took carb completely off again checked a couple things on it tightened all screws and straightened throttle cable. Now I just need to turn up the idle cause it's running great now but I have idle turned down so low from before that it won't idle. Just gotta turn it up though. I had it full throttle in fourth gear going 110kph on the back roads
His and hers
His and hers
