Blue Beastie wrote:
They could not believe that it was not designed to lock.
Quite the opposite - very definitely designed NOT to stay down then the weight is taken off! Imagine the mess if you were to take off with it still down and then lean into your first slight left-hander. Stand digs in, bike does some impressive flip and you're left staring at the sky wondering what happened! I followed another scoot just the other day who had the stand down after they pulled off, struggled to pull alongside in traffic to warn him but thankfully he noticed whilst sat at the next set of lights. Could have been very messy.
The side stands do seem rather a confidence test to use though, rather like that team building thing they get you to do where you close your eyes and fall backwards, hopefully to be safely caught by a colleague behind you! You come to a stop, kick the stand out with your left foot and hold it there, which means that you sat on the scoot upright supported by your right leg on the floor. So to get the bike on the sidestand you have to just 'drop' over to the left, which really takes some guts in my case with no leg available to catch you. You're fine if you confidently hold the stand out fully with your foot, but if you falter and your left foot half goes for the floor, you run the risk of lying down sideways as neither foot not sidestand are in a suitable place to prop the bike.
Or am I doing something wrong here? I've taken to getting off the bike before deploying either stand now, usually the main one. But that's no guarantee it will still be upright when you return. Went out the other morning to find my GTS on its side against another bike in the line-up with a huge scratch and two dents in the side where another bike had fallen into it, presumably causing a bike version of domino rally.
Very, very annoying
