2009 Piaggio MP3 250
Posts: 795 Location: Michigan; USA |
Before going on vacation, I pulled the battery and put it on the trickle charger. After returning home, I discovered that one of the rectangle nuts fell out and I cannot find it. I ordered a new set, but is there any safe way to keep the battery cable attached in the meantime? Wouldn't a cable tie be safe or will it get hot and melt?
Posts: 22763 Location: Harriman, Tennessee, Tn |
a cable tie will NOT give a good enough connection and will cause you problems. Use a good bolt and nut.
old as dirt wrote: a cable tie will NOT give a good enough connection and will cause you problems. Use a good bolt and nut. |
MP3 500
Posts: 1422 Location: Arlington, Republic of Texas |
Posts: 8951 Location: Ashburn, Va. Home to the Internet |
FentonFred wrote: old as dirt wrote: a cable tie will NOT give a good enough connection and will cause you problems. Use a good bolt and nut. |
FunkyMonkey wrote: they do make zip ties now out of metal. Instead of plastic. You might try one of those. |
WEB-Tech wrote: FentonFred wrote: old as dirt wrote: a cable tie will NOT give a good enough connection and will cause you problems. Use a good bolt and nut. |
Anyplace that sells anything power sports, snowmachines, jet skis, should be about to help you out.
Heck if you want to go a few mile west of Carson City I bet my cousins have some old battery bolt kits sitting in their sheds or garages. You could also grind down a thicker nut to make it work, it doesn't have to be a square nut. |
