![]() Modern Primavera (not pictured); Moto Guzzi V-85 TT
Posts: 1790 Location: Los Angeles, CA |
'05 Vespa Granturismo
Posts: 1610 Location: Rancho Cordova, California |
![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni, 2008 Vespa S150
Posts: 8954 Location: Ashburn, Va. Home to the Internet |
Richard H. Lemmon wrote: Where does this ride take place? How much does it cost? How long does it last? |
![]() UTC
MV Santa
Posts: 4905 Location: Sedgwick, Kansas |
MV Santa
![]() GTS250, 1975 VBC, 1980 P200E cutdown, GT200L
FWIW Matt Groening (rhymes with raining) is the creator of The Simpsons and David X Cohen is the force behind Futurama.
![]() MP3 500, Ducati ST4s, Honda Silver Wing
Posts: 2649 Location: Roseburg, OR |
Richard H. Lemmon wrote: Where does this ride take place? How much does it cost? How long does it last? http://answers.yahoo.com/question/index?qid=20090724122354AAjf73V |
![]() UTC
Buddy Pamplona 50cc, Vespa GTV 250ie
Posts: 1519 Location: Saint Louis |
![]() Buddy Pamplona 50cc, Vespa GTV 250ie
Wooooooo hoooooooo!!!! The Vomit Comet!!! I always wanted to do that. Too impossible to even put on my bucket list though.
![]() UTC
Hey... Wait a minute. On Monday I noticed I was up to four roundels. Now this afternoon I see that I have three and a half. Not that those things don't happen, but .... May I say WTF??? I can't imagine anything that I said in the last few days that was in the negative or offensive... Certainly not enough to get a negative enough to go down half a roundel. I'm a bit put off here. Someone is being a bit mean methinks.
Neutral
Mutt The Hoople wrote: Hey... Wait a minute. On Monday I noticed I was up to four roundels. Now this afternoon I see that I have three and a half. Not that those things don't happen, but .... May I say WTF??? I can't imagine anything that I said in the last few days that was in the negative or offensive... Certainly not enough to get a negative enough to go down half a roundel. I'm a bit put off here. Someone is being a bit mean methinks. I gave you a thumbs up for a different post and you're back to four. |
![]() UTC
There is a possible cheaper option, although it may take some work to find the right place. Call an FBO (Fixed Base Operator) in your area, there maybe one that is willing to give rides and do the zero g maneuver or what is called the floating pen trick. If someone will do the flight, it may run in the $200-$300 range depending on length of flight and actual costs which can vary depending on area or equipment cost. It may have to be in an aerobatic aircraft which will may have more restrictive limits.
The thing about it is you would be able to get brief experiences with zero g's but you would have to be buckled in so it wouldn't be what you see in the video where they are moving around and jumping. |
![]() 2013 GTV 300 ie "Victoria" Concept 2 Model D "River of Pain"
Posts: 1383 Location: Aurora, Ontario Canada |
Mutt The Hoople wrote: thank you. I don't know why it bugged me but it did. |
![]() 04 Granturismo- boy thats fun to say
Posts: 1626 Location: Denver, Colorado |
![]() UTC
09 GTS (sold) 2014 NC700XD
Posts: 5016 Location: Charlotte, NC |
![]() 09 GTS (sold) 2014 NC700XD
I saw a clip on Monday on the CNN webpage about an outfit flying an old jet trainer for fighter jet flights and a twin turboprop for 0G flights for civilians...
I'll see later if I can find the clip again. |
Rae wrote: Does indoor skydiving have the same feel? Anyone know? |
bulldog89 wrote: There is a possible cheaper option, although it may take some work to find the right place. Call an FBO (Fixed Base Operator) in your area, there maybe one that is willing to give rides and do the zero g maneuver or what is called the floating pen trick. If someone will do the flight, it may run in the $200-$300 range depending on length of flight and actual costs which can vary depending on area or equipment cost. It may have to be in an aerobatic aircraft which will may have more restrictive limits. The thing about it is you would be able to get brief experiences with zero g's but you would have to be buckled in so it wouldn't be what you see in the video where they are moving around and jumping. Wish he had a cargo plane in the fleet, but they're private planes not commercial, so they are small Pipers and Cessna. |
![]() 2005 Dragon Red Vespa ET4 Speedster
Posts: 2109 Location: Rappahannock Co., Virginia |
WEB-Tech wrote: bulldog89 wrote: There is a possible cheaper option, although it may take some work to find the right place. Call an FBO (Fixed Base Operator) in your area, there maybe one that is willing to give rides and do the zero g maneuver or what is called the floating pen trick. If someone will do the flight, it may run in the $200-$300 range depending on length of flight and actual costs which can vary depending on area or equipment cost. It may have to be in an aerobatic aircraft which will may have more restrictive limits. The thing about it is you would be able to get brief experiences with zero g's but you would have to be buckled in so it wouldn't be what you see in the video where they are moving around and jumping. Wish he had a cargo plane in the fleet, but they're private planes not commercial, so they are small Pipers and Cessna. ![]() |
![]() UTC
![]() UTC
Temporarily Scooterless... :(
Posts: 2116 Location: Albuquerque, NM |
![]() Temporarily Scooterless... :(
For the well-heeled amongst us, there is the 'slightly' more expensive ten to fifteen minute version being offered by Virgin Galactic right here in New Mexico. Our state (one of the poorest in the country) even built the first official 'spaceport' available for commercial use to accommodate the passengers!, at a cost of only $200+ million...
I think flights start at about $250,000 apiece and they have several hundred reservations. Regular commercial flights are supposed to start as early as this winter. http://www.virgingalactic.com http://www.virgingalactic.com/booking/ ![]() The mothership... Already flying in California and New Mexico.
![]() Artist's rendition of the spaceport.
![]() The actual spaceport as it looks right now...
![]() The space pod...
![]() The flight trajectory...
I get people a few moments of zero-G regularly at my part time job..... See www.milehighgliding.com and come on by.....we'll leave the lights on.
![]() LX190 Friday afternoon special, [s]Primavera[/s], S50, too many pushbikes
Posts: 10924 Location: Hermit Kingdom |
Mutt The Hoople wrote: Hey... Wait a minute. On Monday I noticed I was up to four roundels. Now this afternoon I see that I have three and a half. Not that those things don't happen, but .... May I say WTF??? I can't imagine anything that I said in the last few days that was in the negative or offensive... Certainly not enough to get a negative enough to go down half a roundel. I'm a bit put off here. Someone is being a bit mean methinks. |
